hasport wiring for ef
I think you would need to send it to them, but they make a sub harness and with all the info on the site, you should be able to take care of it yourself.
Just do some searching.
I would need to know what model car you have and what engine you plan on putting in. If you have a DX model, you would need to send in your old DX harness AS WELL AS the harness from the engine you want to put in. So if you want a '95 GSR engine in your DX, i would need both COMPLETE harnesses to convert your old one to OBD1. If you have a Si model though, all you would need is our EF-Si-VTEC subharness that's like $70, that adds everything you need to run a OBD0 B16 in your Si hatch/crx. It sounds like a pain in the ***, but it's worth it and I do my best to make sure you get a quality harness that i would be proud to run on my own car or a SEMA show car. It also ensures that if you have any broken sensors on your original harness, that i can replace them. The last thing you want is to spend $3000+ on a motor just to have a wiring problem and the thing doesn't run like it should
We don't keep harnesses pre-made and in stock because the wiring between years is different. Some of the sensors pin into different locations at the shock tower connectors each year, so we work on each harness specifically to make sure it works for your car. If you have any more questions please call us and we'll be happy to answer them for you and get you headed in the right direction
-Dan at HASport
.We don't keep harnesses pre-made and in stock because the wiring between years is different. Some of the sensors pin into different locations at the shock tower connectors each year, so we work on each harness specifically to make sure it works for your car. If you have any more questions please call us and we'll be happy to answer them for you and get you headed in the right direction
-Dan at HASport
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbrian »</TD></TR><TR><TD CLASS="quote">hey i was wondering hasport do u have to send ur harness out for them to make it or do they have them there already made for an ef</TD></TR></TABLE>
DIY it's not that hard.
kid4life4eva
Oct 1, 2005 08:18 PM
