are all 92-95 civic centerpipes the same??
Old Sep 14, 2005 | 05:32 AM
Sleepy_Red_hatch's Avatar
Default are all 92-95 civic centerpipes the same??
as far as hatchbacks are they the same? as in, do they have the same hanger placement and bends etc...? and does a 2 door pipe fit?
Old Sep 14, 2005 | 05:37 AM
JDMlyfestyle's Avatar
yes the mid pipe fits. we swapped out my friends exhaust and he sold it to a kid with a hatch. he just had to get the axle back extended.
Old Sep 14, 2005 | 05:44 AM
Default Re: (JDMlyfestyle)
so a 2 door fits with an axle back extension?
Old Sep 14, 2005 | 05:52 AM
yes as far as i know. BTW the Exhaust was a RSR Ex mag that was swapped. some exhaust companies may have a different design
Old Sep 14, 2005 | 06:11 AM
i want to order one for a 92 Si hatch to pop into my VX....but i duno if it will fit, i know itll probably have to be lenghtened because i have the cat right under the manifold, but hangerwise and axle-back wise, i duno if it will fit.
Old Sep 14, 2005 | 08:53 PM
Default Re: (Sleepy_Red_hatch)
uppity doo?
Old Sep 14, 2005 | 09:12 PM
man this is lame.
Old Sep 15, 2005 | 02:30 PM
i need to know this before i put in the order...are all the hangers located at the smae place?
Old Sep 16, 2005 | 05:26 AM
dwnthehatch's Avatar
I know for a fact that vx midpipe and a si midpipe are different. You can use a si mid pipe if you change the vx exhaust manifold and cat with the si exhaust manifold and cat.
Old Sep 16, 2005 | 05:35 AM
nota-eg's Avatar
Default Re: (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">I know for a fact that vx midpipe and a si midpipe are different. You can use a si mid pipe if you change the vx exhaust manifold and cat with the si exhaust manifold and cat.</TD></TR></TABLE>
I assume you have a VX hatch.
Like that guy said ^
Try to find a Si header, and then get the Si hatch exhaust.
That'll place your cat under your car like the Si and will allow you to bolt the exhaust right up.
bayshitEG6
Dec 28, 2006 01:56 AM
Sleepy_Red_hatch
Sep 13, 2005 08:18 PM
Eskimo
Apr 20, 2002 05:09 AM
