A little vibration anyone?
Old Feb 27, 2002 | 07:11 PM
iwhichisme's Avatar
Default A little vibration anyone?
heres the problem, I recently swapped a b16a into my 91 si, it has a y1 tranny which i plan to swich out wiht my j1. But anyways heres my question, im getting alot of vibration whenever my foot is on the clutch, and when i let off you can here only a little bit of rattling or something going on. When i take off in the car it vibrates bad between 2k and 3k rpms, but then makes this thudding sound when im cruising. Does anyone have any idea what is going on, I thought it might be the throw out bearing, but im not sure. A new clutch and flywheel was installed, could there be a problem somewhere around there in that area, htat is causing this? any help is apprecitated.
peace,
Old Feb 28, 2002 | 05:33 PM
EGh22aEG's Avatar
Default Re: A little vibration anyone? (iwhichisme)
i dont know if this is it but once when my car bottomed out the casing around the flywheel got bent into it and it was rubbing
Old Mar 1, 2002 | 08:09 AM
andrew dc's Avatar
Default Re: A little vibration anyone? (esp169)
did you notch the rear x member when installing the rear mount? and does your altenator have enough clearance?
Cashmoney061596
Feb 7, 2014 12:28 PM
LS spec
Jun 20, 2005 10:16 PM
LS spec
Mar 18, 2005 03:30 PM
gsf4726
Jan 15, 2004 10:00 AM
15psi of fun
Sep 10, 2003 10:43 AM
