(PICS) Magnus Motorsports Talon
Old Sep 13, 2005 | 10:26 PM
2tone_93gt's Avatar
Default (PICS) Magnus Motorsports Talon
Some shots from tonight. Awesome machine.
Old Sep 14, 2005 | 04:00 AM
DaveF's Avatar
Default Re: (PICS) Magnus Motorsports Talon (2tone_93gt)
wtf is up with the front suspension on that car? where is the upper control arm, it looks like its attached to the framerail, lower than the bottom of the shock?
Old Sep 14, 2005 | 04:13 AM
tony1's Avatar
Default Re: (PICS) Magnus Motorsports Talon (Dturbocivic)
lol, damn honda guys. That's a macpherson strut style suspension, no upper control arm. The shock acts as the upper control arm.
Old Sep 14, 2005 | 04:33 AM
DaveF's Avatar
Default Re: (PICS) Magnus Motorsports Talon (tony1)
are you sure tony? it looks like its got a fork on the bottom of the shock ??? usually the bottom of the shock would have a huge metal piece attached to it, with through bolts that would be holding the "hub housing" and the strut inplace.....
Old Sep 14, 2005 | 04:35 AM
tony1's Avatar
lol, i'm an idiot, the older eclipses were mac struts. I don't know what's goin on there.
Old Sep 14, 2005 | 04:39 AM
DaveF's Avatar
maybe magnus or someone that knows them will chime in and explain whats going on int the front susp.
where did he get that stainless v-band exhuast housing??? and are they expensive?
Old Sep 14, 2005 | 04:54 AM
NOPIDRAGS's Avatar
Wondering why they did not post pics of the back of the car? It is now a back half car and still AWD.
You would enjoy checking it out Tony.
Old Sep 14, 2005 | 05:16 AM
99_GS-T's Avatar
The suspension is built by them. Orignally the hub carrier extends above the tire and the upper control arm is attached near the top of the strut tower opening. That car has custom hubs, control arms and mounting points to reduce the weight of the suspension and allow it to clear larger tires.
It would be interesting to know how much time they actually put into modeling that suspension to retain safe alignment thru it's travel.
Old Sep 14, 2005 | 08:35 AM
Kataku2K3's Avatar
Default Re: (99_GS-T)
I don't know **** about Talon's, but I was wondering the same. Still AWD, slicks don't look that big..?
Old Sep 14, 2005 | 08:55 AM
TURBO-TEG's Avatar
Default Re: (Kataku2K3)
yes it still is AWD....and its one crazy machine.....
Old Sep 14, 2005 | 09:10 AM
blitz118's Avatar
Default Re: (TURBO-TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO-TEG &raquo;</TD></TR><TR><TD CLASS="quote">yes it still is AWD....and its one crazy machine.....</TD></TR></TABLE>
So what has it run? The DSM AWD record is now 8.1@176. Can it beat John Shepherd's record?
Old Sep 14, 2005 | 10:46 AM
BoostR41's Avatar
Default Re: (blitz118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blitz118 &raquo;</TD></TR><TR><TD CLASS="quote">
So what has it run? The DSM AWD record is now 8.1@176. Can it beat John Shepherd's record?</TD></TR></TABLE>
it is back halfed so it really won't beat shep since he is still unibody.
just a though they may have swaped over to the 1g suspension because of more/better parts availibility.
I thought the blue one was FWD? I know one of their cars is FWD for sure and this one appears to be on a 2wd dyno for the pics
Old Sep 14, 2005 | 10:55 AM
tony1's Avatar
Default Re: (BoostR41)
Nah, there's an upper control arm, I see it now. Just got rid of the oem one and made a new one lower.
Old Sep 14, 2005 | 11:13 AM
Steve_M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the blue one was FWD? I know one of their cars is FWD for sure and this one appears to be on a 2wd dyno for the pics</TD></TR></TABLE>
The green one (a customer's car) is FWD, this one is AWD.
Old Sep 14, 2005 | 11:26 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">slicks don't look that big..?</TD></TR></TABLE>
You forget, there's 4 contact patches.
Old Sep 14, 2005 | 02:18 PM
GTI2lo's Avatar
Default Re: (PICS) Magnus Motorsports Talon (NDRATECH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NDRATECH &raquo;</TD></TR><TR><TD CLASS="quote">Wondering why they did not post pics of the back of the car? It is now a back half car and still AWD.
You would enjoy checking it out Tony. </TD></TR></TABLE>
Not really a back half, The suspension and subframe that holds the drivetrain is tubular, but the body and chassis remains unibody.
finally the car is done! Business has been busy for marco to time for the car has been tight, glad is finally done. Shakedown passes hopefully this sunday at a local event.
The fabrication on the car is second to none. From the subframe, hubs and suspension. Everything was done for a reason that helps relieve breakage from the stock AWD drivetrain that is notorious for breaking.
Old Sep 14, 2005 | 03:08 PM
99_GS-T's Avatar
It's still not really comparable to Shep's car considering it does not retain the factory suspension mounting points. The tubular crossmembers moves the suspension mounting points.
It should be a pretty sweet Hotrod class car. Which, I beleive, is the same class Shep will be racing in.
Old Sep 14, 2005 | 05:30 PM
Turbo Ric's Avatar
The turbo look to be the same on Shep's car.
Old Sep 14, 2005 | 05:38 PM
ModenaTwinTurbo's Avatar
shep and magnus both cars are amazing
Old Sep 14, 2005 | 05:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">it is back halfed so it really won't beat shep since he is still unibody.
if you already have a locked center diff or a center spool, then all you have to do is just remove the transfercase to make the car fwd.
Old Sep 15, 2005 | 11:57 AM
Finest's Avatar
Default Re: (PICS) Magnus Motorsports Talon (GTI2lo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTI2lo &raquo;</TD></TR><TR><TD CLASS="quote">The suspension and subframe that holds the drivetrain is tubular, but the body and chassis remains unibody.
Yea, we don't want another incident with the rear pumpkin letting loose at the top end again.
Old Sep 15, 2005 | 02:24 PM
the jdmchop's Avatar
Default Re: (PICS) Magnus Motorsports Talon (Finest)
hey bicho does that setup look familar to you ?
bump for a nicley fab'd car
Old Sep 15, 2005 | 08:12 PM
E Town DSM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, we don't want another incident with the rear pumpkin letting loose at the top end again. </TD></TR></TABLE>
Classic Shootout 04 memories.
Old Sep 15, 2005 | 08:28 PM
GTI2lo's Avatar
Default Re: (PICS) Magnus Motorsports Talon (E Town DSM)
"OH MY GOD" Passante 2004 DSM shootout
That Video is priceless!
Old Sep 20, 2005 | 02:33 PM
Lambo123's Avatar
mm how i miss my boosted dsm's...
