radiator cap???
Old Sep 13, 2005 | 07:09 PM
IA95civicDX's Avatar
Default radiator cap???
My radiator cap has a chunk missing in the gasket and i was wondering if this would be a cause for it to over heat. it heats up to about 3/4 up the temp. gauge then it will fall to just under half way on the gauge. I replaced the thermostat just recently also. It also seems to really heat up at idle.
please help me!!
Old Sep 13, 2005 | 07:17 PM
LL2009's Avatar
Default Re: radiator cap??? (IA95civicDX)
as long as your temp gauge doesnt go the H you should be ok but if you say its getting pretty hot at idle check your fans see if there turning on went there suppose
to or maybe run your an direct always on
Old Sep 13, 2005 | 07:21 PM
Default Re: radiator cap??? (LLEO245)
i dont think its the fan because it has only started since i swapped motors and it does kick on
Old Sep 13, 2005 | 07:30 PM
I need help asap!!! please
Old Sep 13, 2005 | 07:33 PM
civic_driver's Avatar
change the cap with OEM
TooFastVTEC
11
Jul 20, 2012 11:53 AM
Freeclowns
11
Apr 14, 2012 04:36 PM
96_coupe
40
Apr 2, 2012 10:35 AM
amej8
Oct 17, 2011 08:00 AM
stevenDAtegra
Jul 23, 2009 12:32 PM
