Need help choosing cams???
Old Sep 13, 2005 | 06:08 PM
MADPROPS's Avatar
Default Need help choosing cams???
I have a 85mm 13.1 ls vtec. I am trying to choose the right cams Considering Skunk stage 2 , Toda spec c, or the hard to find jun 3
Old Sep 13, 2005 | 06:18 PM
kdawgy2k1's Avatar
Default Re: Need help choosing cams??? (MADPROPS)
hey man wassup.... yeah i just bought me a set of Skunk 2 Stage 2's intake and exhaust cams with the dual valve springs I have'nt oredered the retainers yet because i was told that I need injectors and a rail... I already have a type R pump and i was hoping that would be enough... what are you doing about fuel.... and do you think that goin with a JDM stock B16A Engine with header,intake,exhaust, and FPR will be sufficiant
Thanks Kellen
Swift Racing Tech.....
Old Sep 13, 2005 | 06:42 PM
MADPROPS's Avatar
Default Re: Need help choosing cams??? (kdawgy2k1)
I am using a 255 walbro fuel pump, your fuel system will depend on your tuning if you can not tune properly then you will need to upgrade fuel system.
Old Sep 14, 2005 | 06:18 AM
dwnthehatch's Avatar
Have you ever considered the Blox Tuner B's? I have a set and I'm local. dwnthehatch@yahoo.com
Old Sep 14, 2005 | 05:43 PM
MADPROPS's Avatar
anyine using any of these cams
Old Sep 14, 2005 | 05:46 PM
dragonz04's Avatar
Default Re: (MADPROPS)
skunk 2 pro 1's/ skunk 2 pro 2's/ rm m22
any of the above choices would be fine for your bigger bore, higher compression'd motor, but i can't say **** on the skunk 2 stage 2's they just make power
Old Sep 14, 2005 | 05:49 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADPROPS &raquo;</TD></TR><TR><TD CLASS="quote">I have a 85mm 13.1 ls vtec. I am trying to choose the right cams Considering Skunk stage 2 , Toda spec c, or the hard to find jun 3</TD></TR></TABLE>
As far as our cam choices go, you could run M22's or with your displacement and compression M24's would work well too.
Old Sep 14, 2005 | 06:07 PM
MADPROPS's Avatar
thanks guys for your replies, I am still torn but will probably make my finial choice by the end of the week, also debating with s300
Old Sep 18, 2005 | 06:44 AM
MADPROPS's Avatar
are toda spec c still avail? I talked to a couple of different pf people and they say no
97ex2siClone
Jun 27, 2013 11:36 PM
Don E
Feb 28, 2010 09:21 PM
Teamae
Jul 1, 2007 04:48 PM
kdawgy2k1
Sep 20, 2005 06:44 PM
rathead
Mar 4, 2003 07:49 PM
