Wrist Pin install on type s pistons
Well im getting my h22 in in about a week and a half. Its a USDM h22 type sh. I am going to put type s pistons in them on the stock rods (that will work right?). But the helms says you need some kind of hydrolic press thing???? Is this true or is there some other tool i can use? i dont have a mechen shop around here that could do it for me so thats out of the picture.
here are the pistons i want from h motors online
u need to take it to a shop to have them press it in. to remove them, you also need a press to press them out. DO NOT do them yourself.
mgags7 is right about the SH block into a 4th gen without the ATTS unit.
You do NOT need a hydrolic press to get the H22A4 pin off the rods. They are floating pins and can be pushed in/out with a little effort. The pin is held in place with circlips. The H22A1 has press fit pins that you would have to have a shop for disassembly/assembly.
Pirate
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">good luck using an SH block, you better be good at halfshaft adapter plate fabricating.....
do some research...</TD></TR></TABLE>
i will be sending my intermediate shaft to piratemcfred and he will make the plate and "mod" the intermediate shaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">mgags7 is right about the SH block into a 4th gen without the ATTS unit.
Pirate</TD></TR></TABLE>
Confirming
Confirming
can i use regular piston rings. Like if i got to napa and say i need h22a4 piston rings can i get regulare h22a4 rings or do they have to be type s rings
gaydm.accord
Nov 9, 2004 07:58 AM
