Suspension & Brakes Theory, alignment, spring rates....
lowerin 99 tegg
Old Sep 13, 2005 | 05:44 PM
Rudeboy Tegg's Avatar
Default lowerin 99 tegg
arrite im thinkin bout lowerin my 99 ls tegg, i wanna do tein springs, what are sum good shocks i should use when i change my springs and shocks, or should i juss use coil overs... juss wonderin what yall might think
Old Sep 13, 2005 | 08:06 PM
IGotNoSwap's Avatar
Default Re: lowerin 99 tegg (Rudeboy Tegg)
depends on what you wanna do with your car down the ride. if you plan on dailiy driving and just lowering it a lil bit for visual appearance, then teins would be fine with some adjustable shocks like some koni yellows.
if you plan on dailydriving, drag racing, auto x, a good set up would buy some ground control springs on some koni yellows.
Old Sep 14, 2005 | 03:22 PM
racer074's Avatar
Default Re: lowerin 99 tegg (IGotNoSwap)
i also have a teg...it also depends what kind of rims/size you're planning to put on it...if its like 15s then i suggest you to put on some coilovers...juss to make sure its a good drop with the rims..and if you dont like it then you could always adjust them...a set of H&R springs or maybe neuspeed yellows are good....
riseagainst
Nov 2, 2005 09:07 PM
raymondcleung
14
Nov 16, 2003 10:31 PM
sall4real
Jan 28, 2002 08:39 AM
