EG9 htach drag car WHAT WILL IT RUN
Old Sep 13, 2005 | 03:59 PM
spoonEGcivichatch's Avatar
Default EG9 htach drag car WHAT WILL IT RUN
What all will i have to do to the body of my 93 civic hatch to lose more weight and have traction.
so far i strip all interior, but the dash and one seat, doing the back three windows right now in lexan 1/8 thick.
all ac stuff gone.
IM USING A B18B1 MOTOR, (all motor ) JUST TO SEE WHAT I WILL RUN WITH IT.
[B]<U>engine modes</U>[B]
usdm type r piston
stock ls rods
stock crank
aem short ram intake
MSD 6al igniton box
MSD blaster 3 coil
MSD CAP
B&M fuel regulator
AEM fuel rail
skunk2 intake manifold
megan racing 4-2-1 header
full straight 2.5 inch exhaust
crower 403 cams
crower dual valve springs
crower retainers
port and polish
CTR N1 crank pulley (1.8 lBS.)
ACT organic clutch DISK ( THINKING OF CHANGING TO 6 PAD RACE DISK)
ACT heavy duty pressure plate
ACT prolite fly wheel ( 9 lBS.)
ls tranny right now ( BUT TRYING TO GET AN SI TRANNY)
FOCUZ CAM GEARS
nology wires
<U>what do you think it will run in a 1/4 mile?</U>
Old Sep 13, 2005 | 04:06 PM
Default Re: EG9 htach drag car WHAT WILL IT RUN (spoonEG9civichatch)
REMEMBER THIS IS JUST A START.
Old Sep 13, 2005 | 04:07 PM
i for got rd 325 cc injectors, and welbo fule pump 255, and sone hondata s200
Old Sep 13, 2005 | 04:58 PM
9SECQTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonEG9civichatch &raquo;</TD></TR><TR><TD CLASS="quote">REMEMBER THIS IS JUST A START.
maybe you should start clicking the blue check icon (spell check) before posting?
go to the track and find out what it runs is the best advice you will get
Old Sep 13, 2005 | 07:08 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonEG9civichatch &raquo;</TD></TR><TR><TD CLASS="quote">What all will i have to do to the body of my 93 civic hatch to lose more weight and have traction. </TD></TR></TABLE>
as far as traction...you didnt make any mention to any suspension or radial/slick upgrades that you have!!
as far weight reduction..you pretty much have a good start (get above taken care of 1st)
as far et?....??????? get to the track!!!...i've seen people w/ 300whp not get into 12's and i've seen 200whp in the 11's
Old Sep 22, 2005 | 07:06 AM
95civic4dr's Avatar
Default Re: EG9 htach drag car WHAT WILL IT RUN (12SEC CIV)
eg9 for your info is the ferio 4dr eg... not a hatch!!
Old Sep 22, 2005 | 07:13 AM
CHEETAH's Avatar
Default Re: EG9 htach drag car WHAT WILL IT RUN (95civic4dr)
get the trunk molded to fiberglass or CF ... look at JDM companies mayeb they already make one for Ferio or whatever its called there.
heater core, bumper supports, inner door supports rear seat cross frame that separates the trunk you can cut out, cut out all metal ont he rear doors and just leave a shell.
assume this is not a street car since you're doing lexan (btw, I don;t think will save you too much).
13sechatch
Aug 20, 2008 12:41 PM
Eclypz
Mar 4, 2006 01:31 PM
racingant
Feb 2, 2006 04:37 PM
JDM b18 Hatch
Nov 17, 2005 05:49 PM
94SHOWLS
May 4, 2004 03:28 AM
