Need some advice on my newly installed clutch.
Old Sep 13, 2005 | 03:11 PM
dirtysohc79's Avatar
Default Need some advice on my newly installed clutch.
Just got my clutch put in about 2 weeks ago. (I took it to a shop) Now my tranny grinds going into 2nd, 3rd and 4th gear when driving hard and shifting fast. Also, it makes this funny noise and sounds like the clutch disc is grinding on the flywheel while in nutrual with clutch engaged. When I press down on clutch pedal it goes away. And lastly the balance of my front tires seem to be a little off. It feels fine going about 50mph but once I hit around 80mph it feels like sh*t and gets even worse when I step on the brakes. Could something be loose or banged out of alignment when they popped out the axles? Please give me some advice cause I'm really thinkin about taking the car back to the place and opening a can of worms on them.
Old Sep 13, 2005 | 03:50 PM
anybody with some clutch experience please give me some advice on what could be the problem.
Anybody?
Thanks
Old Sep 13, 2005 | 03:53 PM
Suck my DX's Avatar
Default Re: (dirtysohc79)
ever heard of a break in period for ur clutch? ur suppossed to take it easy for the first 5-800 miles...
Old Sep 13, 2005 | 03:56 PM
igy's Avatar
igy
Did you happen to have the flywheel changed or resurfaced? If you did it sounds like it could be that the flywheel bolts are loose. That would cause all of your problems, even the front tires feeling out of balance.
Old Sep 13, 2005 | 04:02 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (igy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igy &raquo;</TD></TR><TR><TD CLASS="quote">Did you happen to have the flywheel changed or resurfaced? If you did it sounds like it could be that the flywheel bolts are loose. That would cause all of your problems, even the front tires feeling out of balance.</TD></TR></TABLE>Could be, but I doubt a reputable (hopefully) shop would not torque something as importand as those. Since we have no idea what sort of clutch was put in the car we have no idea if the sound with the clutch depressed isn't just clutch chatter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">ever heard of a break in period for ur clutch? ur suppossed to take it easy for the first 5-800 miles...</TD></TR></TABLE>LOL yeah you should.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtysohc79 &raquo;</TD></TR><TR><TD CLASS="quote">Now my tranny grinds going into 2nd, 3rd and 4th gear when driving hard and shifting fast. </TD></TR></TABLE>You probably pounding the hell out of your synchros beating it on a virgin clutch. This problem will only get worse if you continue to beat it..
Old Sep 13, 2005 | 04:04 PM
CardDealer's Avatar
Banned
Default Re: Need some advice on my newly installed clutch. (dirtysohc79)
Modified by CardDealer at 4:34 PM 11/16/2006
s_vares
Acura TL, RL & ZDX
Jul 16, 2011 04:40 AM
lude98SH
Feb 21, 2006 07:28 AM
vietdragontekx
Aug 27, 2005 06:27 PM
FLCivic
15
May 31, 2004 09:22 AM
SystemGSR
Jul 1, 2001 04:43 PM
