rpm not working, si gauge cluster on 99-00 civic dx
Old Sep 13, 2005 | 12:41 PM
91b16crx's Avatar
Default rpm not working, si gauge cluster on 99-00 civic dx
I installed a 99-00 civic si gauge cluster on a 2000 civic dx and the rpm is not working. I tap the blue single wire on the driver side strut tower to the distributor blue wire and still nothing. Don't have manual so if anybody has some advices it would greatly be appreciated.
Old Sep 13, 2005 | 12:43 PM
Kouki-EK9's Avatar
Default Re: rpm not working, si gauge cluster on 99-00 civic dx (91b16crx)
I installed a CTR cluster into my 99 cx. I didn't tap into any wires, I just plugged what was on my original cluster into the new one and everything worked fine.
Old Sep 13, 2005 | 12:44 PM
undertheradar's Avatar
Default Re: rpm not working, si gauge cluster on 99-00 civic dx (Kouki-EK9)
Maybe you got a damaged gauge.....it should just plug in and work great.
Old Sep 13, 2005 | 03:48 PM
91b16crx's Avatar
Default Re: rpm not working, si gauge cluster on 99-00 civic dx (undertheradar)
The gauge came off my friends car right before I put it in and it was working fine.
I did the same thing he did to make it work (tapping the wires)
Old Sep 13, 2005 | 03:52 PM
Kouki-EK9's Avatar
You shouldn't have to tap any wires. I'd say undo whatever wiring you did and just plug in what you unplugged from the other one but you may have damaged the tach by running a bad wire to it.
Old Sep 13, 2005 | 04:15 PM
91b16crx's Avatar
When I tapped the wire it moved a little bit (very little) I also heard that 96+ civic dx wire is not connected to the distributor to read the rpms. Is there a way I can test out the gauge cluster directly to the distributor to see if the rpm is even working? It also looks like the harness that connect to the distributor was all cut at one point. I need to know what wire goes to what on the distributor.
Tong.Y
May 19, 2010 07:49 PM
Danethomp
Sep 18, 2006 11:56 PM
SHIFKU(EF9 HOPE FUL)
Sep 21, 2005 08:02 AM
opiumdaze
Aug 10, 2005 01:25 PM
GIJenkins
Jan 18, 2003 06:08 PM
