D SERIES TURBO KIT ***CHEAP CHEAP CHEAP*****
FOR SALE
COMPLETE CUSTOM TURBO KIT FOR D16 CIVIC/DEL SOL
INCLUDES:
DSM intercooler
Custom bent IC piping
Ar.42 turbo both oil and liquid cooled NO SHAFT PLAY
water lines, oil lines all included with kit!
Turbo good for around 16psi to redline
Custom intake w/ K&N filter
Stock first gen DSM BOV included w/flange already welded on upper IC pipe
Custom turbo manifold included, bolts up to any D SERIES head.
probably much more im forgetting! PM ME FOR ANY MORE INFO NEEDED
YOU WILL NEED TO HAVE A MUFFLER SHOP FAB UP A DOWNPIPE OFF THE TURBO AS ONE IS NOT INCLUDED (there is a short downpipe, about 6 inches off the turbo, you can run open downpipe like that but if you want to be street legal, you will need to do what is mentioned above)
LOOKING FOR AROUND 600 DOLLARS FOR EVERYTHING LISTED ABOVE
PM ME FOR ANY MORE DETAILS, THIS NEEDS TO GO QUICK!!!!
Modified by GSRmorris at 12:52 PM 9/13/2005
Modified by GSRmorris at 2:35 PM 9/13/2005
Modified by GSRmorris at 2:35 AM 6/29/2007
INCLUDES:
DSM intercooler
do you have any pics? please send them to punkrocrjeff@aol.com
also does it come with a boost controler b/c 16 psi will blow my motor. lol
LOL , by "turbo is good for 16psi to redline" i was saying that if you wanted, you could HOLD 16psi to redline. the wastegate pressure is set at about 6-7 so im sure youll be fine.
Pics will come soon and ill be sure to email them to you!
sorry i didnt really explain the whole PSI thing to you.
Ill do better.
I said that the turbo would be good for about 16psi to redline, meaning that if you chose to put on a boost controller and crank the boost up really high that it would be able to support 16psi at your RPM redline. BUT the turbo's wastegate spring is set for only about 6-7psi, so you can just bolt it on and go and itll be fine for your engine as long as its tuned properly, no boost controller required uless you want MORE boost.
Ill do better.
still up for sale? pics? cash in hand. saralizbeth@msn.com
Blowensi
Aug 19, 2006 09:45 AM
