Suspension & Brakes Theory, alignment, spring rates....
Where can i get the best deals on suspension, and other structural parts?
Old Sep 13, 2005 | 07:22 AM
pny1981's Avatar
Default Where can i get the best deals on suspension, and other structural parts?
I am thinking coilovers, but i do not want to go to low. I just want it to be stiffer, body wise, and not so much spring wise. The roads i drive on are crap. So where are the best deals? Oh i have a 96 rs integra.
Old Sep 13, 2005 | 12:21 PM
trtxdenny's Avatar
Default Re: Where can i get the best deals on suspension, and other structural parts? (pny1981)
well if you're worried about ride-height and want a stiffer chasis, then coi-overs are the way to go... you don't need to worry about height because with real coilovers you can adjust the height to whatever you want it to be and it gives you a good spring rate, and makes the ride more comfortbale
Old Sep 13, 2005 | 12:29 PM
PIC Performance's Avatar
There are several ways to stiffen up the chassis itself. Tear it apart, and use seam-welds everywhere like an ITR. Or weld in a roll cage. Add frame locks. I'm sure there's more.
But whats the point if you're going to be riding around on stock suspension? Sure, you will have minimal chassis flex around the turns, but you'll be rolling like a boat.
Potential2nr
Suspension & Brakes
22
Jan 9, 2012 12:32 PM
92cb7sk8er
51
Mar 19, 2011 02:33 PM
HeatherJ
Aug 9, 2006 07:28 AM
fycus
Suspension & Brakes
17
Jul 15, 2006 07:54 PM
nek0
Jun 26, 2003 01:42 AM
