Information about VSS
Old Sep 13, 2005 | 06:25 AM
IIBoostaholicII's Avatar
Default Information about VSS
Im pretty sure my VSS is messing up considering my speedo needle will jump randomly from place to place and sometimes not even work period. The problem sometimes seems to fix itself as it does not always freak out like it does. So i have come to the conclusion that it is either a wire problem or the VSS itself. I have a 97 B18 swapped into my civic. Is the sensor for this fully electronic? or does it use a cable? im not quite sure some help would be apriciated on if it is electric or cable drawn and how to approach fixing the problem if it is not the VSS.
thanks
Old Sep 13, 2005 | 06:59 AM
sudds's Avatar
Default Re: Information about VSS (IIBoostaholicII)
https://honda-tech.com/zerothread?id=1364578 scroll down and you will see a pic of the vss. It's next to the back mount.
Old Sep 13, 2005 | 02:00 PM
Mista Bone's Avatar
D Tranny Guru
clean the connector at the tranny, fixess 99% of the VSS issues
Old Sep 13, 2005 | 02:07 PM
JDM-EJ1's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">clean the connector at the tranny, fixess 99% of the VSS issues</TD></TR></TABLE>
Old Dec 10, 2005 | 01:09 PM
madhatter2199's Avatar
ok well i cleaned the connector at the tranny and no good. i replaced the sensor and no good. i checked all the grounds i could find no good. so what do i do? i have an AEM EMS ecu instead of stock so im not throwing code so i have no idea should i try to re wire it?
Old Dec 10, 2005 | 02:48 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Information about VSS (madhatter2199)
How did you clean the connectors? Usually it's a bad connection from the plug. Stick in a couple strands of wires in each and replug it.
Old Dec 28, 2005 | 07:21 AM
dognutz's Avatar
Default Re: Information about VSS (GapxGuy)
sticking the wire in there cleans it or is there something more to it.
sir_crx_says
Transmission & Drivetrain
Nov 21, 2013 09:39 PM
pin0y209
10
Jan 16, 2008 07:56 AM
Roy2377
Nov 11, 2004 11:49 AM
crxzcracer
May 5, 2004 12:37 PM
Caveman74
Jan 6, 2003 04:10 AM
