timing belt broke, but tried to start the car, engine okae?
Old Sep 12, 2005 | 07:37 PM
mingbling96's Avatar
Default timing belt broke, but tried to start the car, engine okae?
my friend's timing belt broke while going 40mph. He thought it was something else, so he cranked the engine a bunch of times. Do you guys think that damaged the engine at all? Its a h23a btw. thanks
Old Sep 12, 2005 | 07:44 PM
LL2009's Avatar
Default Re: timing belt broke, but tried to start the car, engine okae? (mingbling96)
it should be ok but most likely you would have to change the plugs there probably soak in fuel other than that i dont think ill do any damage to your motor
Old Sep 12, 2005 | 07:50 PM
B20TDC2's Avatar
Default Re: timing belt broke, but tried to start the car, engine okae? (LLEO245)
like stated most likely it will be ok, but there could be some damage. after you get a new one on try doing a leakdown test to see if everything is ok.
when we initially started my car a nut fell into the timing cover and got caught in the belt and shredded it , luckily no damage though
Old Sep 12, 2005 | 09:33 PM
verbal-assassin's Avatar
most likely, no.
new engine. insurance fraud. type r engine
after that, if they raise your premium, swictch insurance.
Old Sep 12, 2005 | 09:50 PM
Keno20's Avatar
Default Re: timing belt broke, but tried to start the car, engine okae? (verbal-assassin)
Yip should be ok. Mine snapped and I didnt know it.... tried to start it up again several times!!!
discokid3
Dec 16, 2018 06:10 PM
aedude006
Sep 12, 2016 05:20 AM
WillyD6869
Jun 13, 2005 11:46 AM
egturbo
Feb 14, 2005 03:41 AM
OgunplayGSR
Jan 19, 2003 02:55 PM
