ITR 5 Lug Conversion - any performance increase or purely cosmetic?
Old Sep 12, 2005 | 06:32 PM
numotive's Avatar
Default ITR 5 Lug Conversion - any performance increase or purely cosmetic?
I was thinking about throwing a 5 lug conversion on to my gs-r and was wondering if this upgrade actually improves anything performance wise or if people just did it merely for visual enhancement? The only thing I could think of would be the larger rotars for breaking. Other than that, do they do anything else?
Old Sep 12, 2005 | 06:36 PM
Naruto's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (numotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote"> The only thing I could think of would be the larger rotars for breaking. Other than that, do they do anything else?</TD></TR></TABLE>
Yea...they look reaaaal nice Performance wise....like you stated, better braking. Of course...I can't think of anything else it would do aside from attracting more attention to your car
Old Sep 12, 2005 | 06:39 PM
numotive's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (Naruto)
Hmmm... gonna be tough to decide if its really worth the cash or not. Kind of a lot of money for something so minor that is mostly cosmetic.
Old Sep 12, 2005 | 06:56 PM
Dogginator's Avatar
Daisy... Daisy...
You can have the larger brakes without the 5-lug.
https://honda-tech.com/zerothread?id=734560
The rear wheel bearings are slightly wider on the ITR 5-lug compared to the other Integras.
Old Sep 12, 2005 | 06:57 PM
dFreezy's Avatar
its probably 80% cosmetic, 20% functional increase in braking
Old Sep 12, 2005 | 07:18 PM
KOALA YUMMIES's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (dFreezy)
You have a crapier much more expensive and limited selection of wheels, the parts (pads and rotors etc) are harder to come by and cost more, you can run a minimum size of 15" diameter wheels, its heavier (search for the total weight difference), but everyone in the appearance cosmetic forum will be straight up trippin and saying crap like "yoooo dawg dat 5-lug is the shiznit for realz!".
Old Sep 12, 2005 | 07:22 PM
Senbonzakura's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">but everyone in the appearance cosmetic forum will be straight up trippin and saying crap like "yoooo dawg dat 5-lug is the shiznit for realz!".</TD></TR></TABLE>
Bahahahahah
Old Sep 12, 2005 | 08:05 PM
numotive's Avatar
lol yeah, i don't see any real advantage to make it worth while. i can always get some bigger powerslot rotars or something if i really want to. but then again.... ahhhhh shiznit i would have 5 lugs mang! just like a type r! lol
Old Sep 12, 2005 | 08:17 PM
SilverDc2's Avatar
i put a 5lug on my integra and the braking is pretty much the same because im using the stock M/C and booster...
i regret getting 5lug i wish i still had my 16" almighty grey regamasters
Old Sep 12, 2005 | 08:36 PM
JDMkidGSR's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (SilverDc2)
IT GIVES YOU A 89 FT. LBS OF TQ AT THE WHEEL............
JUST KIDDING THEY JUST LOOK REALLY PIMP
Old Sep 12, 2005 | 08:41 PM
5 Speed AP2's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (92bluteg_ls)
more BLING than anything.
Old Sep 12, 2005 | 08:49 PM
Kendall's Avatar
I had a 5 lug conversion on a hatchback I had earlier this year, I only put it on because the stock 4 lug had worn out pads and rusted wheel bearings (it was easier to install the 5 lug than to replace the messed up components) One good thing is that it does add weight to the bottom of the car, thus transfering the weight balance down, but unless you track the hell out of it, you really won't be able to notice a difference. But it does get a lot of attention, both good and bad.
Old Sep 12, 2005 | 08:56 PM
numotive's Avatar
Default Re: (Kendall)
i find it amazing how having 5 lugs instead of 4 can get you that much more attention, especially since it doesn't even do anything performance wise... they are friggen LUG NUTS
Old Sep 12, 2005 | 09:10 PM
Kendall's Avatar
Default Re: (numotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote">i find it amazing how having 5 lugs instead of 4 can get you that much more attention, especially since it doesn't even do anything performance wise... they are friggen LUG NUTS</TD></TR></TABLE>
Most Honda-informed automotive circles (excluding the track ****** and purists) will see it as some form of a status symbol, an indication that you and your car possess some level of superiority.
-Kendall, dedicated automotive purist
Old Sep 12, 2005 | 09:11 PM
Naruto's Avatar
yep....and the only way I really noticed any increase in my braking when I did the 5 lug was that I bought the stainless steel braided lines, ceramic pads from checker, and...well...I had to use prelude type SH calipers ( used washers to evenly space the fronts ) both front and back. I also used DOT 4 brake fluid ( though I really don't think it made THAT much of a difference ). It did stop a bit better than stock though ( but it felt like a HUGE improvement ). But like someone said, I won't really notice anything realistically unless I track my car
Old Sep 12, 2005 | 09:17 PM
Kendall's Avatar
Default Re: (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote"> It did stop a bit better than stock though ( but it felt like a HUGE improvement ). But like someone said, I won't really notice anything realistically unless I track my car </TD></TR></TABLE>
The biggest difference will be in the longevity of braking performance under hard driving. The larger brakes will be able to withstand a lot more stress before fading, which can be critical on a road course or in an autocross. Pad choice will make a bigger difference in ultimate stopping ability.
Old Sep 12, 2005 | 09:20 PM
BS 22's Avatar
I would rather spend the money on something else...If I was ballin outta control, then yeah I'd probably do the conversion.
Old Sep 12, 2005 | 09:36 PM
numotive's Avatar
Default Re: (BS 22)
yeah i just dropped 1550 on a brand new j4d lsd type r tranny so i'ma have to save for a while if i want the conversion. its like almost a grand right?
Old Sep 12, 2005 | 09:53 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote">yeah i just dropped 1550 on a brand new j4d lsd type r tranny so i'ma have to save for a while if i want the conversion. its like almost a grand right?</TD></TR></TABLE>
If you get the conversion off of a JDM car, then You'll have to purchase new axles as well. USDM conversions don't require new axles, but usually cost a bit more than the JDM ones.
Old Sep 12, 2005 | 10:16 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The biggest difference will be in the longevity of braking performance under hard driving. The larger brakes will be able to withstand a lot more stress before fading, which can be critical on a road course or in an autocross. Pad choice will make a bigger difference in ultimate stopping ability.</TD></TR></TABLE>
Oh I know....and since I'm not tracking the car yet ( car is currently being daily driven until I can get a beater fixed )....I'll wait on looking into pad choice
Old Sep 13, 2005 | 01:30 AM
:jdmshmaydm:'s Avatar
If you get the conversion off of a JDM car, then You'll have to purchase new axles as well. USDM conversions don't require new axles, but usually cost a bit more than the JDM ones.</TD></TR></TABLE>
You'll only need the axles if you get JDM ITR 5 lug. If you go with the JDM CTR or USDM ITR, then you'll be ok using your stock axles.
Old Sep 13, 2005 | 03:57 AM
95lstegman's Avatar
Default Re: (Gatecrasher21AF)
it's already been stated, guys (and gals). 5-lug conversion is what you do when you don't know what to do with the better part of $1000. ITR brakes almost bolt onto 3G tegs and others using teg spindles and such. that goes for the front and the rear, BTW. and you can do it for less than half the price of the 5-lug conversion. so there you have it, there is NO, i repeat, N-O performance benefit of 5 lugs. it's just like it sounds. wow, now you have another lug nut and bolt on each wheel, and now you can run Type-R wheels, which are mighty handsome if i might add. but in any case there is no other reason than Type-R wheels to do it.
Old Sep 13, 2005 | 05:09 AM
For_Sale's Avatar
mostly cosmetic, but still some function.
other than those mentioned above, i can think of 1 more plus to 5lug. the extra 5th wheel stud distributes stress to the lugnuts more evenly. every 4 lug honda ive had has always had problems with front wheel studs getting messed up. not with 5lug!
Old Sep 13, 2005 | 06:24 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">You have a crapier much more expensive and limited selection of wheels, the parts (pads and rotors etc) are harder to come by and cost more, you can run a minimum size of 15" diameter wheels, its heavier (search for the total weight difference), but everyone in the appearance cosmetic forum will be straight up trippin and saying crap like "yoooo dawg dat 5-lug is the shiznit for realz!".</TD></TR></TABLE>
fo shizzle mah rizzle dizzle nizzle.. it's off the hizzle..
Old Sep 13, 2005 | 07:02 AM
95lstegman's Avatar
Default Re: ITR 5 Lug Conversion - any performance increase or purely cosmetic? (da_truf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guest16 &raquo;</TD></TR><TR><TD CLASS="quote">mostly cosmetic, but still some function.
i call bullsh!t. the lug bolts do NOT exhibit substantial shear stress, as most people believe. they endure medium to high normal tensile stress, and they take it like a pro (they're designed for it). the hub is designed to interlock perfectly with the center hole of the wheel. they're designed that way. it ensures 1) the wheel goes on perfectly straight, not off-center, and 2) that the lug bolts do not take shear stress. that's why they make hub-centric rings.
now, the reason your lug bolts get messed up is because when you put the wheel on, you drag the holes of the wheel across the bolts getting the wheel to sit properly on the hub. pay attention next time you do it and you'll see what i mean. then try your best to quit doing it, and go to SEARS or something and get a carbide tape and die and die all your lug bolts and tap all your lug nuts. good as new
