fuel pump
Old Sep 12, 2005 | 06:20 PM
rudeness's Avatar
Default fuel pump
is there a relay for my fuel pump that I should check before I replace the pump? if so, where the hell is it?
Old Sep 12, 2005 | 07:16 PM
rolledthatho's Avatar
its called a main relay, just search main relay under the ef forums you will find boocooo's of info
but to help some, its located to the left of the fuse box kinda up in the corner where your feet go on that side wall
Old Sep 12, 2005 | 07:38 PM
ripperbone's Avatar
Default Re: fuel pump (rudeness)
your fuel relay is behind the hood release latch
Old Sep 12, 2005 | 07:57 PM
up under some stuff tho
Scarekrow
Oct 11, 2015 08:05 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
YodajdmEK4
Oct 3, 2005 09:24 AM
