h22 all motor with h23 crank
Old Sep 12, 2005 | 03:16 PM
hatchy54's Avatar
Default h22 all motor with h23 crank
what would i have to do to to put the h23 crank in my h22 with type s pistons and type s rods and would it b a good idea to do it
Old Sep 12, 2005 | 03:42 PM
ranta18's Avatar
Default Re: h22 all motor with h23 crank (hatchy54)
TONS of info out there. Use the search and you'll find a lot. Here's a recent one:
https://honda-tech.com/zerothread?id=1365478
Unless you deck plate the block, you can't run the H22 rods.
Old Sep 13, 2005 | 06:08 PM
hatchy54's Avatar
Default Re: h22 all motor with h23 crank (ranta18)
NONE OF THAT ANSWERS MY QUESTION
Old Sep 13, 2005 | 07:10 PM
ranta18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">Unless you deck plate the block, you can't run the H22 rods.</TD></TR></TABLE>
That should of.
Run the H23 crank, H23 rods, and the Type-S pistons. The H22 rods are too long when combined with that stroke. The pistons would stick out .169" out of the hole. Not good.
Old Sep 14, 2005 | 05:46 AM
iakona's Avatar
listen to this man. he knows.
Old Sep 14, 2005 | 06:16 AM
H23vtecEG's Avatar
Default Re: (iakona)
i just finished one of these the other day. motor runs great, cant wait to dyno it with the type-s cams...... use h23 crank and rods.....other options like pistons are up to you
Old Sep 14, 2005 | 01:25 PM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy54 &raquo;</TD></TR><TR><TD CLASS="quote"> would it b a good idea to do it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">The pistons would stick out .169" out of the hole.</TD></TR></TABLE>
hatchy54, I think it would be a good idea for *you* to stack up 7 head gaskets and let us know how it goes...
Old Sep 14, 2005 | 02:37 PM
ranta18's Avatar
Default Re: h22 all motor with h23 crank (flyrod)
OOPS... hehe. I ment .085" out of the hole. I forgot to divide the difference in strokes by 2 ((95mm - 90.7mm) / 2) / 25.4 = .085"
Thats still a little less than 3 times the thickness of the head gasket though.
Modified by ranta18 at 11:56 PM 9/14/2005
thechamp657
Nov 8, 2007 09:59 AM
zo4000
May 26, 2007 08:25 AM
s-tech
May 4, 2005 11:14 AM
JDMBB2
Nov 13, 2003 10:39 AM
JBk24crx
Jul 25, 2003 09:01 PM
