Test pipe & O2 sensors..
Old Sep 12, 2005 | 02:13 PM
IntegraCF21's Avatar
Default Test pipe & O2 sensors..
I'm planning on buying a test pipe from here for my '01 OBDII GS.. http://www.kteller.com/store/p...d/211
They have the option for (2) O2 sensor bungs, but from what i've read, i'll still need an O2 simulator correct? I'm kinda confused on all the stuff regarding a test pipe and what needs to be done if you get one.
Old Sep 12, 2005 | 02:23 PM
iH8RICERZ's Avatar
Default Re: Test pipe & O2 sensors.. (HondaTeg6)
not sure if this'll answer your question, but i'm running a test pipe on my obd1 gsr.... i had one o2 bung on my test pipe, plugged in my o2 sensor in that bung, and worked perfectly fine.... no codes or anything. I think you would only want a simulator if you didnt want to plug in your o2 sensor.... not sure how it is with obd 2
Old Sep 12, 2005 | 02:25 PM
Well from my understanding, with OBD2, there is an O2 sensor before the cat and an O2 sensor after the cat and the second one is what people were having problems with.
Old Sep 12, 2005 | 04:17 PM
Will a highflow cat make the exhaust any louder?
Old Sep 12, 2005 | 05:03 PM
Also, if I were to get a CEL, would it really matter and could I just ignore it?
Old Sep 12, 2005 | 05:07 PM
ebp_dc2's Avatar
u need a simulator cuz ur secondary o2 is gonna be all thrown off. I'd suggest a high flow cat but even with that u still might get a CEL
Old Sep 12, 2005 | 05:12 PM
drift4jesus's Avatar
Default Re: (HondaTeg6)
The purpose for the 2nd o2 sensor is for the computer to see if the cat is doing its job. It has no other purpose except to check for emissions. All OBD2 cars have them. I know that all over the Ford sites you can find places to purchase MIL eliminators. I'm not positive how it works but I think it has a capacitor in it that you wire in to the O2 sensor wiring. It tricks the computer by sending it a different voltage than the first o2 sensor (upstream of cat). If the 2 sensors send back the same signal then the ecu knows that the cat is gone and it may put the car into a limp mode or closed loop (at least thats what it does to fords)
I know that you can purchase the parts at radio shack to make one of these MIL eliminators for something like $7
Hope that helps a little bit
Old Sep 12, 2005 | 09:40 PM
TODA GS_R's Avatar
Default Re: (drift4jesus)
thats very true. i work at a muffler shop and thats the main reason why we dont staight pipe OBDIIs. we striaght pipe OBDIs all the time (sshh) with no prob.
Old Sep 12, 2005 | 09:46 PM
.water's Avatar
Default Re: (TODA GS_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODA GS_R &raquo;</TD></TR><TR><TD CLASS="quote">thats very true. i work at a muffler shop and thats the main reason why we dont staight pipe OBDIIs. we striaght pipe OBDIs all the time (sshh) with no prob.</TD></TR></TABLE>
so with high flow cat with o2bung will not throw any codes?
also if i use test pipe, tell me more about how to- the cheap way.
Old Sep 12, 2005 | 10:27 PM
Chewie's Avatar
Default Re: (JunkyDC2)
i have a 2.5" high flow cat and a fireball exhaust, no problem with any cel. 99 gsr btw.
Old Sep 12, 2005 | 11:44 PM
TODA GS_R's Avatar
Default Re: (Chewie)
this setup works perfectly fine...i would recommend this way with obd2. the cheapest way? well if you have your stock exhaust piping...what you can do is buy a highflo cat like the guy above then got to a shop to straight pipe your resignator (pretty much for noise control) and pickup any after market muff.
i just save money buy bending my on piping (non mandrel with aluminized piping 2.25) if sum1 decided to get full piping at my shop...itd probably run bout...$100
Old Sep 13, 2005 | 03:00 AM
No one answered this yet..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg6 &raquo;</TD></TR><TR><TD CLASS="quote">Will a highflow cat make the exhaust any louder?</TD></TR></TABLE>
Old Sep 13, 2005 | 11:25 AM
bump
I would like to be able to order this today..
Old Sep 13, 2005 | 11:38 AM
ebp_dc2's Avatar
a high flow cat should keep it pretty quiet, but freeing up the exhaust is going to make it louder either way for the most part
Old Sep 13, 2005 | 11:43 AM
I guess my main question is if you did buy the test pipe with the 2 O2 bungs, it would still create a CEL?
Old Sep 13, 2005 | 12:15 PM
BlackLudeSi's Avatar
yes you would need the kit to trick the ecu into thinking you cat is working otherwise you get a CEL and limp mode
Old Sep 13, 2005 | 03:10 PM
Anyone know where to get a cheap O2 simulator then? Also, where does it mount?
Old Sep 14, 2005 | 05:15 PM
Anyone?
Old Sep 14, 2005 | 05:54 PM
Vi3tboy's Avatar
another thing you could do which was what i did was do a obd1 conversion. all you need is a obd1 vtec ecu a conversion harness and your set. any questions or porblems let me kno. i also have a test pipe on my car. obd1 is much better!
Old Sep 14, 2005 | 05:56 PM
AllSpedup04's Avatar
Default Re: (Vi3tboy)
i had a dc header to highflow to exhaust and threw no codes on my odb2 teg
Old Sep 14, 2005 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vi3tboy &raquo;</TD></TR><TR><TD CLASS="quote">another thing you could do which was what i did was do a obd1 conversion. all you need is a obd1 vtec ecu a conversion harness and your set. any questions or porblems let me kno. i also have a test pipe on my car. obd1 is much better!</TD></TR></TABLE>
About how much would all of that cost and where can you get it from?
Old Sep 14, 2005 | 06:46 PM
Vi3tboy's Avatar
find a ecu wherever. they go for 40-100 bucks. then find a conversion harness which should run you around 60-75 bucks. conversion harness i found locally.
Old Sep 14, 2005 | 07:14 PM
TOPFUELER's Avatar
Hope this helps out. https://www.casperselectronics...honda
Also I did a Search at Team-Integra.net They had some helpfull insight to your questions...
Old Sep 14, 2005 | 07:15 PM
boosted k20's Avatar
well your saying that the ECU will throw a CEL if the Primary and secondary O2 sensors are showing the same voltage? so how about u make a voltage divider with resistors on the secodnary O2 sensor wire by the ecu so it tricks the ecu into seeing a different voltage. (which O2 sensor usually sees a higher voltage? the PO2 or the SO2? which ever one sees the lesser of the voltage put the voltage divider on that wire.)
Old Sep 14, 2005 | 07:23 PM
TODA GS_R's Avatar
its really not that easy...like vietboy said...just convert to OBDI
