D16Z6 Build, my list, what would you recommend?
Well, I have decided that I want to see how much I can pull from her once I get the new Radiator (wife is happy about this, as it is her car). Here is the list of parts I am probably going to order, However, I need help on high compression pistons, rods, bearings etc... I have no idea what sizes to go with, also I want a high reving engine (maybe 9-10,000 if possible)
List:
Engine:
Skunk2 70mm Throttle Body
Skunk2 Stage 1 Cam
Skunk2 High Compression 0.5mm Oversized Valves
Skunk2 Racing Valve Springs
Skunk2 Titanium Retainers
Skunk2 Blue Anodized Cam Gear
Skunk2 Intake Manifold
AEM Cold Air Intake system
AC Blue/Carbon Fuel Rail
Nology Hotwires Blue
Denso Iridium Plugs
ProFire D-10 CD Ignition Coil
MSD Distributor Cap Adapter and Coil Wire
TenzoR Valve Cover Black
Hyper Ground System S-Type Blue
Hyper Voltage Silver Body/Blue Wire
Unorthodox Racing Underdrive Pulley set
DC Sport 4-1 Header
Skunk2 cat-back stainless exhaust
stainless high flow cat
Drivetrain:
Clutch Masters Stage 3 Clutch/Flywheel
Phantom Grip Limited Slip Diff
Suspension:
Skunk2 Front and rear Camber Kits
Intrax Front and Rear sway bars
Skunk2 Coil Over Kit 0-4inch drop
Skunk2 Front Upper Strut Bar
Skunk2 Rear Lower Arm Bar
I really do need help on internals.
List:
Engine:
Skunk2 Stage 1 Cam
Denso Iridium Plugs
DC Sport 4-1 Header
Drivetrain:
Suspension:
I have been considering that too. How much do you think I could pull, MAX, from a D16? I was looking for the swap, I was thinking maybe a B18 or an H22, but then decided "maybe I will see how mcuh I can pull from the D16, since its my wife's car anyway, she doesnt need what I could do to a Bseries or H22".
L.A.OutlawFWD
Apr 21, 2011 10:56 AM
sleepycivix
Dec 28, 2002 09:08 AM
