f**king o2 sensor!
Old Sep 12, 2005 | 12:22 PM
vtec-adykt's Avatar
Default f**king o2 sensor!
whats up with the o2 sensor on the crx's. Is is just me? I keep checking the ecu when the cel comes on, and all i get is a code 1. I replaced the sensor with a new one, the light went off for a while. Then the next day it was back. the connection is good. I even removed the plastic connectors that click together and crimped the wires directly together. but still keep getting that annoying check engine light. Is there something else that would be causing this code?
Old Sep 12, 2005 | 12:34 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
i had the same problem. it was so annoying that i was almost suicidal. https://honda-tech.com/zerothread?id=1325377 check the thermostat ground, there should be 2 next to each other. make sure they are separate, tight, and clean. that was my problem.
Old Sep 12, 2005 | 01:09 PM
vtec-adykt's Avatar
Default Re: (CarsonSurfer)
i'll check it out tonight.
greyejcoupe
Oct 3, 2009 10:48 AM
mattkins91
Mar 1, 2009 02:07 PM
civicsaremean
Jul 15, 2007 07:59 PM
the_0ne
Jul 16, 2006 08:01 PM
Koyoloeor
Oct 13, 2005 04:57 PM
