i have a coupple questions
Old Sep 12, 2005 | 09:48 AM
Megaton's Avatar
Default i have a coupple questions
first i was wondering if a h22a1 head would fit on a f22a1 block
i looked it up and there the same displacment 2156cc
another thing is my accord lx 93 f22a1 GETS REALLY HOT
when idlleing within a matter of minutes the temputure guage is at the top.
and when we start moving it goes down really fast.
any ideas i really aperciate it.
Old Sep 12, 2005 | 09:58 AM
fw190bvi's Avatar
Default Re: i have a coupple questions (Megaton)
the head will "fit"...but some extensive modifications need to be done in terms of oil and coolant holes in the block and head
when was teh last time your coolant was flushed?
Old Sep 12, 2005 | 10:03 AM
Megaton's Avatar
Default Re: i have a coupple questions (fw190bvi)
i don't think it ever has.
i'll check later.
would that have to be custom made is that reallyuexpensive to cool the h22a head on the f22a1 block?
Old Sep 12, 2005 | 10:05 AM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Megaton &raquo;</TD></TR><TR><TD CLASS="quote">i don't think it ever has.
i'll check later.
would that have to be custom made is that reallyuexpensive to cool the h22a head on the f22a1 block?</TD></TR></TABLE>
its very expensive...and ive only seen it done like two or three times...people do it because the F block responds to boost MUCH better than the H block...so they use it for motors they plan on boosting
Old Sep 12, 2005 | 10:15 AM
Megaton's Avatar
thatd be what i'm planing on but i doubt i have the kind of money to cool the h22a head.
Old Sep 12, 2005 | 12:12 PM
Schmitey's Avatar
Make sure your fans are turning!!! Since you said idle I'm assuming its not a problem until you stop, which means your thermostat is working. Could be a bad relay or blown fuse (big 20 Amp or so under the hood).
You also have to make custom piping for the water pump, change gears and tensioner, and a whole bunch of messy crap. There's a hella long write up somewhere like 40 pages, I forgot who did it. Oh and then he realized he didn't have enough room for the turbo and cut a hole in the hood I believe.
Old Sep 12, 2005 | 12:53 PM
Megaton's Avatar
Default Re: i have a coupple questions (Schmitey)
thanks all take a look at it.
and post another thred if i find anything out.
jordan_rael_420
Apr 6, 2011 07:35 AM
holmesnmanny
Oct 29, 2010 03:50 AM
holmesnmanny
Aug 9, 2010 12:06 AM
wheelmaneg6
Jun 5, 2006 09:58 PM
nelsond
Mar 22, 2006 09:58 AM
