Best New Mod For My Setup Help....
I am currently running a 98' Hatch With A Internally Stock B16B Motor Swap, B16B LSD Tranny(8LB. Flywheel, ACT Street/Strip Clutch), Stock B16B ECU, J's Racing Carbon Fiber Intake, DC 4-1 2.5", Carsound Hi-Flow Cat, Apexi World Sport Cat-Back, and a B&M Fuel Pressure Regulator.
Just wanted some advice on which dirrection to take as far as new power mods. I want to keep this All-Motor.
I am kinda a newbie on the Honda scene....Thanks In Advance.
i would get a kenji ecu and run hondata! but before that i would get some cams and gears first. that is where you have to decide how serious you want to go because you can go really wild or really mild! you have a good set of cams in it already so whatever cams you get wont be as good of a jump in power but you can make some more power with the right cams! good luck!!!
first off what kind of goals are you looking for and how deep are your pockets!
maybe look into investing in a good header. also look into hondata, crome, uberdata for management. then tune it......
motormike40
Dec 26, 2007 10:21 AM
turboedc2
20
Mar 8, 2006 08:18 AM
Sorry_Officer
Sep 11, 2005 12:08 AM
