Honda S2000 Honda S2000
Coilover Help, Height Adjustment
Old Sep 12, 2005 | 06:47 AM
Project SSAP1's Avatar
Default Coilover Help, Height Adjustment
hey guys...I jsut wanted to know is there any way to adjust ride height without disconnecting either the bottom or the top of the shock to allow it to rotate??
This is for the coilovers that adjust via the bottom perch without messing w/ the preload. Is the only way to adjust the height by removing the bottom bolt or top of the shock???
Old Sep 12, 2005 | 07:22 AM
WowOzYouRock's Avatar
Default Re: Coilover Help, Height Adjustment (Project SSAP1)
iono what you meant eaxctly ... <--- soo confused
anywho, y do you need to remove the bolts for? just jack the car up and adjust the perch using a perch wrench COUNT the thread and do the same thing on the other side
Old Sep 12, 2005 | 08:18 AM
Default Re: Coilover Help, Height Adjustment (Y2K_S2K)
well i think i found a way...these coilovers adjust ride height by the lower perch...There are 3 purches..the top 2 are to adjust preload and the botom is to adjust ride height....
well..i think i found a way...if you loosen the bottom perch..then lossen the top 2 perches and by using the wrenches turn the top 2 perches in the same direction at the same time..this should move the entire shock body up and down
Old Sep 12, 2005 | 08:34 AM
no NOOB!! dont lossen the two top perches if you dont wanna mess up the preload ... just lossen the bottom perch in the bottom mount ... the purpose of the small perch is to lock up the big perch that hold the spring when you turn it in the opposite direction
Old Sep 12, 2005 | 08:50 AM
lol...damn man...but when u loosen the bottom mount you cant move the shock unless you remove the lower a-arm bolt from the shock to turn the shock to raise and lower the height
sorry for my noob questions..but i use to have tein RA and the only way to adjsut height was to mess with the preload with the top perches..lol
Old Sep 12, 2005 | 08:58 AM
Default Re: (Project SSAP1)
yeah but you when you turn the big top perch with the small perch in lock possition, you will able to turn the whole suspension in opposite direction w/o removing the LCA bolt .. how hard is it to understand!!!? lol
IM me foo ... x00stookiex
Old Sep 12, 2005 | 10:36 AM
devnull's Avatar
d2's?
If so you loosen the very bottom nut that locks the bottom portion. Then make sure the top 2 perchs are very securly tighten againest each other (top clock, bottom counter clock) Then to lower turn the top clockwise. To raise turn the bottom counter clock.
The above method you will notice that you are turing the perchs againest each other but that is it moving the threaded shock collar up or down the arm shock mount.
http://www.d2racingsports.com....n.jpg
Not sure but I think Tein work the same way.
Old Sep 12, 2005 | 11:00 AM
Default Re: (badboypolar2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badboypolar2 &raquo;</TD></TR><TR><TD CLASS="quote">d2's?
Not sure but I think Tein work the same way.</TD></TR></TABLE>
i already explained it to him over AIM's ... hes a noob like that
Old Sep 12, 2005 | 05:53 PM
THANKS Y2K_S2K...that was soooo easy..lol
Modified by Project SSAP1 at 3:05 PM 9/13/2005
Old Sep 12, 2005 | 08:28 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Atleast you got an S2K before asking this question.
nOObs
Old Sep 13, 2005 | 07:03 AM
Default Re: (NAallTheWAY)
thanks u jerk!!!...i had a different set of coilovers that adjusted by messing with the preload...the new set i have is rather different...
i have a simple question...im sure all of you didnt know how to do some things yourself at one point...its all good though...
Old Sep 13, 2005 | 07:30 AM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">Atleast you got an S2K before asking this question.
nOObs </TD></TR></TABLE>
he's no noob
Old Sep 13, 2005 | 12:52 PM
ken-e's Avatar
Default Re: (Nishant)
i had to take my whole suspension off to adjust the ride height
Old Sep 13, 2005 | 12:55 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (ken-e)
Poor guy, you shouldn't have to.
Old Sep 13, 2005 | 12:57 PM
Default Re: (ken-e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken-e &raquo;</TD></TR><TR><TD CLASS="quote">i had to take my whole suspension off to adjust the ride height </TD></TR></TABLE>
dummy haha JK ... just ask question and we r here to help
Old Sep 13, 2005 | 01:21 PM
ken-e's Avatar
Default Re: (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">
dummy haha JK ... just ask question and we r here to help </TD></TR></TABLE>i would've, but it seems like you guys's hands have been busy with spinless noobs asking how to do burn-outs or what to do to their car
Old Sep 13, 2005 | 06:24 PM
minivanman's Avatar
Oz is my hero!
Old Sep 14, 2005 | 06:45 AM
Default Re: (minivanman)
Nick is my idol!
mr_munro
Suspension & Brakes
15
Jan 26, 2012 11:53 PM
initialvtec
Suspension & Brakes
39
May 19, 2007 11:48 PM
torqueless
Suspension & Brakes
Aug 19, 2005 11:21 AM
DoctorGSR
Suspension & Brakes
17
Mar 6, 2005 06:52 PM
