wat would cause this
Old Sep 12, 2005 | 05:40 AM
91-lsvtecsi's Avatar
Default wat would cause this
is this normal? bad? any idea wat would cause this?
Old Sep 12, 2005 | 05:55 AM
goforbroke's Avatar
MEAT PATTY
Default Re: wat would cause this (88lscrxsi)
Bad valve seals, bad valve job.
Old Sep 12, 2005 | 06:05 AM
Default Re: wat would cause this (goforbroke)
how can i fix this? price range?
Old Sep 12, 2005 | 09:19 AM
bump
Old Sep 13, 2005 | 12:39 PM
fmrprojects's Avatar
were you ovberheating. it could be a blown headgasket
Old Sep 13, 2005 | 02:06 PM
hybrid_vtec's Avatar
Default Re: (fmrprojects)
looks like you were running rich or running fuel additives that casued the buildup in the chamber and on the valves. It also looks like you leaking some oil.
Since the head is off, I would replace the valve seals, resurface the head, get a new headgasket, check the block deck surface for flatness, and possibly look into getting a valvejob done; just to cover all areas.
Also check your PCV valve to makesure it hasnt gone bad which can cause it to blow oil all in the IM. Piston Rings could be another possibility.
Old Sep 13, 2005 | 04:35 PM
Default Re: (hybrid_vtec)
yea it was overheating and needs a new gasket , how much would a valve job cost?
Old Sep 13, 2005 | 05:48 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (88lscrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88lscrxsi &raquo;</TD></TR><TR><TD CLASS="quote">yea it was overheating and needs a new gasket , how much would a valve job cost? </TD></TR></TABLE>
yea i was too last friday.. which really sucks
Old Sep 15, 2005 | 08:27 AM
Default Re: (turbofienD 04)
vavle seals are new , oil is there cause i have the head laying on it side. running rich? more on this please.
markers.
Feb 6, 2010 04:54 PM
lsvtechatch92
Dec 23, 2007 02:02 PM
huepowered
Apr 4, 2006 12:10 PM
rmcdaniels
Nov 14, 2004 04:27 PM
Evs-One
Oct 12, 2003 10:55 AM
