JDM Header Question
I did a search but came up w/o an answer so sorry to bother about the same old topic over and over.
I just need to know all the parts (besides the header) that have to be purchased in order to complete the install. Also if someone could please give me the Carsound Cat #. Thanks in advance.
BTW this is for a 2000 GSR.
Thanks again.
Thanks again.
JDM Donut
3 bolt gasket
bolts/nuts
2-1/2" Carsound 94006, but that's the p/n for the universal weld in piece. You can buy them with the flanges and O2 bung already installed and then it becomes a true bolt in.
3 bolt gasket
bolts/nuts
Thnaks for the reply.
About the Carsound cat, do they have one that comes with the flanges and O2 bung that you can order or do you have to call them up and secial request it?
Thanks.
[Modified by Got-VTEC, 2:20 AM 2/28/2002]
Thanks.
I just bought the header and went to a mufflershop that sells carsound cats and had them install everything. I needed to purchase a new exhaust manifold gasket and a donut gasket. The S2K donut gasket is exaclty the right size thats what i used. Since i only have one 02 sensor and the header already had a hole for it i did not need a hole in the cat. Different story if youre ODBII
