Thinner Headgaskets
Old Feb 27, 2002 | 12:31 PM
Wallace996's Avatar
Default Thinner Headgaskets
What does raising the compression do to the powerband? Does it increase hp/tq over the entire band or do you sacrifice somewhere?
Also, if one were to do this, what kind of tuning would be needed, as in timing etc.
Thanks.
Old Feb 27, 2002 | 05:15 PM
GTM's Avatar
GTM
Default Re: Thinner Headgaskets (Wallace996)
Raising the compression in a motor would give you better power/torque across the entire powerband. Torque gains will be especially noticeable in the lower revs.
Make sure the mating surfaces on the head and block are perfectly flat if you plan on using a thinner head gasket.
Old Feb 28, 2002 | 06:08 AM
keithv's Avatar
Default Re: Thinner Headgaskets (GTM)
a thinner headgasket can raise the compression some, but it also changes the air flow in the combustion chamber. i think this is a cheap way of getting more power...if it all works out. do it right but getting different pistons.
just my 2 cents.
b00stedOne
Jul 28, 2014 09:56 AM
bluzohh6
24
Jun 4, 2012 12:49 PM
d.n.d.
Jul 17, 2005 08:39 AM
spaceman
Mar 30, 2004 09:36 PM
mbsi
Apr 21, 2003 07:46 AM
