obd0 to obd1 is this the kit that I need to convert all the wiring?
Old Sep 11, 2005 | 06:55 PM
TH33G4MON3's Avatar
Default obd0 to obd1 is this the kit that I need to convert all the wiring?
I need to convert my obd0 wiring to obd1... so I was just wondering if this kit I found will do what I need? thanx for any and all help!
http://www.rywire.com/sitob161.shtml
is that everything I need? $190
thanx guys
Old Sep 11, 2005 | 10:20 PM
s2kkid's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (TH33G4MON3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 &raquo;</TD></TR><TR><TD CLASS="quote">I need to convert my obd0 wiring to obd1... so I was just wondering if this kit I found will do what I need? thanx for any and all help!
thanx guys
Looks complete Ive never done one but Looks like everything youd need.
I saw on the site where it says the guy will wire in the subharnes if you send yours to him.. You Might want to do that for a nice clean error free install.
Old Sep 11, 2005 | 10:45 PM
TH33G4MON3's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (vtecluder97)
yeah it does seem like a good idea... I think we can do it tho I just like to double check everything. it doesn't hurt thanx
Old Sep 11, 2005 | 11:03 PM
phateless's Avatar
the mechanic that's going to do my swap said the obd0 gauges may not be compatible with an obd1 computer. is this true, or is it just a matter of getting the harness adapter? if i put my obd1 engine/ecu into an obd0 car am i forced to use an obd1 cluster?
Old Sep 11, 2005 | 11:34 PM
TH33G4MON3's Avatar
Default Re: (phateless)
no you should be fine all my friends never had problems. as long as you have the obd1 ecu and conversion. which you do. so you should be fine I've never heard of anyone having problems
Old Sep 15, 2005 | 01:12 PM
phateless's Avatar
ok cool. so speedo, cel, fuel and temp should all work fine? and worst case i guess i can figure out a way to mount my gsr cluster in there...
robcrx
Apr 8, 2006 07:07 PM
89eFRACER
Apr 2, 2006 09:50 PM
TH33G4MON3
13
Sep 12, 2005 09:12 AM
spcrxracer
Jul 22, 2004 09:44 AM
HondaCivicSiR1
Feb 26, 2004 06:48 PM
