problem after installing skunk2 adjustable spring w/kybgr2
finished installing all four skunk2 adjustable springs w/kyb gr2, the front came out perfect but the back is just way to unacceptable, theres a 3 finger gap on it. and if you look under the fender wells the springs are not even all the way up where the upper rubber pillow mounts are at and the adjustable part of the springs are already all the way down to the cups of the strut, so if anybody can help me with this i double check the springs already i got the right springs just like what says on the instruction manual. so pls if theres someone that can help me with this.
can the trailing arm bushing can add any problem
So what is between the top of the spring and the upper mount? Have you lowered the car down off the jack? Sounds weird.
between the upper pillow mount and the spring nothing but space between them, and if you asking me if the jack is down, yes it is and i even put down the e-brake.
pinoysi2000
Suspension & Brakes
Jul 23, 2013 08:20 PM
bigBOI_92DA9
Sep 12, 2005 05:40 PM
