b16 Injector wont close.and other things! pls help. Searched.
Old Sep 11, 2005 | 03:16 PM
RaysBoomBoomLude's Avatar
Default b16 Injector wont close.and other things! pls help. Searched.
I redid (redid, as in, it was working before, just wanted to make it cleaner)
and when I reinstalled the harness.
It wont crank? I turn the key to the on Postion, and no CEL light comes on? push the clutch in, and the CEL comes on? and wont turn off.
I try to start it, and theres some constant clicking, not like a Starter clicking, but like a Relay of some sort under the dash...
I check the Starter Relay. I check with my multimeter, and it is fine ( I have the helms PDF)
So! an Injector wont turn off, it keeps pumping in gas. so it floods till theres gas comming out of the intake manifold. I remove the POS battery terminal, and it stops. I remove the Spark plugs and theres only gas in cylinder 4. I pump all the gas out.
I check resistance on the injector. Injector 4 is 2.57 (helms says 1-2.5 is alright) is that injector toast?
CLIFFS:
B16 wont start, started before I cleaned up the wires,
INJECTOR wont stop firing. Resistance is 2.57( helms sayd 1-2.5 is alright)
Old Sep 11, 2005 | 03:43 PM
Default Re: b16 Injector wont close.and other things! pls help. Searched. (LaFawnduh)
wow, this moves fast.
RobEK
Sep 28, 2009 06:30 PM
dbailey
18
Jan 4, 2007 01:35 PM
wcknockoutk86
Dec 26, 2005 04:11 PM
RaysBoomBoomLude
Sep 12, 2005 01:02 PM
incognitoracerr
Oct 2, 2003 10:29 AM
