tapping sound from under car while going over bumps
Old Sep 11, 2005 | 11:51 AM
peja43916's Avatar
Default tapping sound from under car while going over bumps
While I am driving over bumps I keep hearing a sound like metal on metal hitting against each other from the engine bay on the driver's side. At times I can even feel it on my feet when it hits . I checked all my suspension bolts and nuts and everything is tight . I heard from another member on here that it might have something to do with my tie rods. What do I check for that could cause this sound? Thanks in advance.
Old Sep 11, 2005 | 12:00 PM
YeuEmMaiMai's Avatar
Default Re: tapping sound from under car while going over bumps (peja43916)
check to make sure that you don't have loose crap in the trunk and that your tire is securely mounted and that the jack is securly mounted.
If you have a hitch on the back like I do, it may be the exhaust banging against it.
Old Sep 11, 2005 | 12:11 PM
peja43916's Avatar
Default Re: tapping sound from under car while going over bumps (YeuEmMaiMai)
the sound if clearly from the front of my car in the engine compartment and not in the trunk or the exhaust. I can feel it on my feet at times also when it bangs.
Old Sep 11, 2005 | 12:12 PM
peja43916's Avatar
Also, my tires are all securely mounted so I know that is not the problem.
Old Sep 26, 2005 | 01:58 PM
peja43916's Avatar
I took my car to a mechanic and he told me the sound is coming from my bottom sway bar bushings being worn out and there is too much play in there. Does anyone know what he is talking about?
Modified by peja43916 at 3:19 PM 9/26/2005
Francis N
Honda Civic (2001 - 2005)
Oct 17, 2015 09:55 AM
Vague
Apr 26, 2015 01:05 PM
BKJJ77
23
Mar 23, 2012 05:52 PM
BB4_JDM
Jan 23, 2009 09:43 PM
oovvutt
18
Dec 10, 2007 03:46 PM
