changed map sensor, but code is still there.....what now??
Old Sep 11, 2005 | 09:49 AM
hatchinprogress's Avatar
Default changed map sensor, but code is still there.....what now??
i replaced the map sensor (92 gs integra) with an extra one i had(not sure from what car) the #'s on both sensors were almost the exact same...... so i put the new sensor on (but i havent even started the car yet) i checked for codes(jumper wire) and code 3 is still there
should the code just go away?(since i changed the sensor) or do i have to unplug the batt. to clear the code??
Old Sep 11, 2005 | 09:55 AM
TrueUntilDeath.com's Avatar
Default Re: changed map sensor, but code is still there.....what now?? (hatchinprogress)
did you try and reset teh ECU and drive around for a day or two?
Old Sep 11, 2005 | 10:01 AM
Default Re: changed map sensor, but code is still there.....what now?? (Loveless.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless. &raquo;</TD></TR><TR><TD CLASS="quote">did you try and reset teh ECU and drive around for a day or two?</TD></TR></TABLE> no, i havent<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> (but i havent even started the car yet) code 3 is still there
should the code just go away?(since i changed the sensor) or do i have to unplug the batt. to clear the code??</TD></TR></TABLE> would the code just go away if the sensor was changed? or does the batt. have to be reset(unplugged)
Old Sep 11, 2005 | 10:03 AM
not 100% sure, but when i get check engine lights and i fix the problem, i usually reset the ecu and it never comes back
Old Sep 11, 2005 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless. &raquo;</TD></TR><TR><TD CLASS="quote">not 100% sure, but when i get check engine lights and i fix the problem, i usually reset the ecu and it never comes back</TD></TR></TABLE> thanks
Old Sep 12, 2005 | 05:34 AM
jetmech53's Avatar
With any code after power is turned off the light will not come on unless the problem comes back again. The code however is "set" in the ECU, you must remove the back-up power in order to clear the code.
You can check your you map sensor by applying vacuum and checking the voltage. Haynes repair manuals have the spec's.
bmoua
Aug 8, 2007 01:34 PM
ViXoN Hatch94
Apr 17, 2006 07:11 PM
D C 5
Jun 19, 2005 11:01 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
NZcrx88
Aug 9, 2002 03:18 PM
