Hondata 2 is in!!
Old Feb 27, 2002 | 10:05 AM
Bert's Avatar
Default Hondata 2 is in!!
All,
Got my Hondata 2 (P28 ecu, OBDii->OBDi conversion harness) today and installed it. Install was so easy I could do it! The only slightly trick part was running the lead to the interface box out of the ecu... I dremeled a little spot off of the edge of the ecu cover for it to pass through since I couldn't see how they did it in the instruction manual.
Even with a semi-generic base prog, the difference is night and day in how the car runs. No more cel's, hesistation, etc. Even idle is waay smoother. The only thing is my kick panel doesn't fit too well over all that stuff now, but I can live with it. I mounted the interface box directly onto the ecu with 2-sided tape since I couldn't see anywhere else to put it.
Now, what do I have to do to get rid of the Field unit? It's turned off right now. I tried unplugging it completely and that was bad. Good thing I tried starting the car without it before I spiked the Field unit in the parking lot.
Old Feb 27, 2002 | 10:51 AM
Vtec integra's Avatar
Default Re: Hondata 2 is in!! (Bert)
you gonna dyno it anytime soon?
let me know of some dyno numbers
i am seriously thinkin of getting the hondata stage 2
what was needed to be done on the whole kit
before you could start your car?
and how much did you pay for yours?
Old Feb 27, 2002 | 11:00 AM
Bert's Avatar
Default Re: Hondata 2 is in!! (Vtec integra)
Yeah, I'm going to dyno and get a full custom program sometime in the next couple months. Podium Performance is about a half hour from me, so I'll probably be going there. Last time I dyno'd with zero tuning and the car definitely not running right I put down ~175hp, 120tq
I got a chipped P28 ecu, base program to my specs, OBD2->OBD1 conversion harness and Hondata 2 from Brian at Prospeed for under 900 shipped. I'm not sure he'd want me posting the exact price so I won't.
Once I got the package, the only tricky part whatsoever was running the lead to the interface box out of the ecu... I dremeled a little spot off of the edge of the ecu cover for it to pass through since I couldn't see how they did it in the instruction manual. All instructions are available fon hondata.com. After that I simply removed the old ecu and plugged the new one in, mounted the interface unit with some 2-sided tape, switched off the Field SFC/VTEC controller and the car ran beautifully.
Old Feb 27, 2002 | 12:00 PM
canuck-mx6's Avatar
Was your P28 already socketed so that it could accept the burned chips with the new maps?....or did you do that yourself!
Old Feb 27, 2002 | 12:36 PM
Bert's Avatar
Default Re: Hondata 2 is in!! (canuck-mx6)
Yeah, the chip came socketed and with a base map (set up to my parameters) plugged in.
I barely trust myself to solder two wires together.
waynebennett77
Engine Management and Tuning
Feb 16, 2013 09:52 AM
RudeLude
Nov 3, 2007 12:32 PM
Simmerman
13
Jan 20, 2006 07:45 PM
jiahanhao
Apr 6, 2004 04:41 PM
BoostedH23a1
Mar 3, 2003 10:09 AM
