Can you use integra injectors on H22?
Old Feb 27, 2002 | 09:46 AM
BoM's Avatar
BoM
Default Can you use integra injectors on H22?
can u use integra injectors if you have its ECU along with it?
Old Feb 27, 2002 | 09:51 AM
boomslang's Avatar
Default Re: Can you use integra injectors on H22? (BoM)
Not stock sized ones, they are way too small.
Old Feb 27, 2002 | 10:07 AM
BoM's Avatar
BoM
Default Re: Can you use integra injectors on H22? (Inlinefour)
car - 89 Civic hatchback SI
engine is 92-95 h22a
ECU - a b-series motor, i dont' remember.
Injector - are integra, but bigger size (RC)
has new B+M FPR and gauge and new walbro pump. The car had starting problems
so we tested everything and replaced the problem (Fuel pump and FPR.)
now were clueless, we sent the car to SKR performance, and had them install new injectors, he favored the integra injectors because of the ECU to match i suppose.
problem is the injectors keep shutting off.
can anyone help me with the saturated and peakhold types?
and if you can see where the problem in this is?
i've done a search, but couldn't find out what cars need a resistor pack for the injectors. anyone know?
holla back.
[Modified by BoM, 2:11 PM 2/27/2002]
JG Luder's Avatar
Call RC Engineering. Easiest and most definitive way to get an answer.
Old Feb 27, 2002 | 10:17 AM
boomslang's Avatar
You need a resistor pack if you are using peak and hold injectors.
Old Feb 27, 2002 | 11:56 AM
DirtyLude's Avatar
Measure the resistance between the two contacts on the injector with a regular multimeter. If the resistance is under 7 ohms, you need a resistor pack. It's as simple as tht.
96civic808
Apr 22, 2010 12:23 PM
russianswty
27
Nov 14, 2006 06:30 PM
jansenrw
Nov 21, 2005 06:16 PM
r30slick
Jan 10, 2002 10:02 AM
