slicks with no LSD... still able to pull good 60's?
Old Sep 10, 2005 | 08:42 PM
Slammd Sol's Avatar
Default slicks with no LSD... still able to pull good 60's?
If i run a nice set of slicks on my stock differential (no lsd), will I be able to pull good 60's?.. (around a 1.8?) Setup is a sohc vtec @ 10psi.
Also whats a good size and brand slick to get? Im tired of pulling shitty 2.3-2.4s. I ran at the track a few weeks back with a pair of 20x7x13 Avon autocross slicks and they spun like crazy. Best all night was a 2.37 sixty foot, 14.2 @ 100mph. I really want to hit 12's!
vids from 2 of my runs:
http://www.slammdsol.com/track1.mpeg
http://www.slammdsol.com/track2.wmv
Old Sep 11, 2005 | 08:47 AM
Slammd Sol's Avatar
ttt
Old Sep 11, 2005 | 09:03 AM
91tealhatch's Avatar
Default Re: slicks with no LSD... still able to pull good 60's? (Slammd Sol)
well my buddy with a 91 civic, with a zc dohc pushing 10 psi, has no lsd and slicks he does 2.0 0-60 ft but he claims he sucks at driving it, so im sure you can get at least a 1.8, and his slicks are pretty thin, i can't tell you which ones to buy, but good luck dude
Old Sep 11, 2005 | 09:07 AM
Luserkid's Avatar
Default Re: (Slammd Sol)
You should ask in the drag forum. With good driving you could get good 60 fts.
Old Sep 11, 2005 | 04:46 PM
Slammd Sol's Avatar
t t t
Old Sep 11, 2005 | 05:45 PM
japan4racing's Avatar
if you are only trapping 100mph you are not gonna hit 12's. get some descent slicks and dont be scared to break something and if you can drive it you will hit high 13's
Old Sep 11, 2005 | 05:52 PM
Slammd Sol's Avatar
Default Re: (japan4racing)
yeah im thinking maybe high 12s with 2-3 more pounds of boost and good traction.
Old Sep 11, 2005 | 06:06 PM
b18ccivics's Avatar
i have a 95 civic ex full interior and some audio equipment with b18c with no lsd running 6.5 pounds of boost and yesterday with micky tompson 22/8/15 inch slicks at 11psi and ran
60' 1.875
330 5.478
1/8 8.449
mph 84.27
1000 10.992
1/4 13.140
mph 105.39
Old Sep 11, 2005 | 06:39 PM
Slammd Sol's Avatar
Default Re: (b18ccivics)
so 22x8 is a good size slick to go with?
Old Sep 11, 2005 | 07:10 PM
get you some more boost and traction willing you will run good times
as for this other guy 13.1@105...thats hooking! good time man!
Old Sep 11, 2005 | 07:12 PM
22x8 slicks will be fine for you...a buddy of mine had a integra with 392 whp on 22 inch slicks he could run consistent 11.6's but he was trapping in 5th gear..you have less power so you wont have that problem...he got 24 inch slicks and ran 11.4 trapping at the top of 4th. good luck with it man.
Old Sep 11, 2005 | 08:27 PM
nsxmatt's Avatar
I was running 22x8 M&H slicks on my Civic and getting 1.6-1.7 60ft's, no lsd. Best 60ft was a 1.60. At that power level I didn't see much of a advantage to a LSD since at the track both slicks would spin.
Old Sep 11, 2005 | 09:24 PM
ek9vboi2's Avatar
depending on ur rpm redline and the type of tranny you are using...also the power. i've been looking for a set for a while and have done some research
i'll take into consideration that you have an EX tranny on ur sohc vtec motor. it revs up to around 7k +/- 100-200rpms. you make around 200whp, if not lower.
them 22" slicks sound good to me. unless u trap over 122mph u will stay in 4th. around 90mph ends 3rd gear. thats shifting at 6.8k rpms.
Old Sep 11, 2005 | 11:25 PM
Slammd Sol's Avatar
Default Re: (ek9vboi2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">depending on ur rpm redline and the type of tranny you are using...also the power. i've been looking for a set for a while and have done some research
them 22" slicks sound good to me. unless u trap over 122mph u will stay in 4th. around 90mph ends 3rd gear. thats shifting at 6.8k rpms.</TD></TR></TABLE>
woot woot.. thanks bro
Old Sep 12, 2005 | 05:24 AM
ek9vboi2's Avatar
Next time you need to figure out 1/4 mph, rpms, etc...basically MPH in w/e car on the strip use this:
http://autocrossing.com/cgi-bin/gearcalc.cgi
Just plug in the tranny, tire diameter, redline.
Old Sep 12, 2005 | 07:34 AM
Fitti's Avatar
yep you should be able to get good 60' times. It will take some practice. But my friends and I usually are able to pull 1.6 - 1.8 on 24.5's.
You will probably want to learn how to load the tranny so that you don't break anything though. You probably don't just want to drop the clutch or else you might be picking up a few pieces of parts
dookieK9
Nov 5, 2007 10:34 AM
dazcivic
Feb 24, 2007 06:13 PM
wleach11
Jun 21, 2005 12:12 AM
civic disobedience
Nov 8, 2002 05:38 AM
