HELP ! CANT EVEN REVERSE or GO UP HILLS !!!
Old Sep 10, 2005 | 06:59 PM
NeWnMpR0VeD's Avatar
Default HELP ! CANT EVEN REVERSE or GO UP HILLS !!!
i recently did a swap to a JDM d15b motor... not too sure on what tranny i have but i believe its a basic D series 5 speed tranny... i also have a lightened OEM flywheel with a BRAND NEW gripforce stage 1 clutch.... i'm still in the breaking in process... and my question to everyone is, lets say i'm going up a regular size city hill... i can enter the hill going like 40... and if i dont keep up the speed, my **** was STRUGGLE up the hill... i recently tried going up a hill today and it struggled so bad in 1st n 2nd gear... i was literally flooring it in 1st gear and the RPM was steady at 1,000 and the speed didnt go any higher than 5 mph... and on top of that, it was slowly DECREASING... i couldnt make it up the hill so i just busted a bitch... also, i popped it in reverse and tried making it up a driveway type of hill and u can just feel the ?clutch/flywheel? spinning... as it was spinning and i was tryna go up it wouldnt even make it up... u can smell the clutch so bad, smelt as if it was BURNT... it made some sort of weird noise as i was tryna back it up... trust me, i know how to drive... but i dont know whats goin on... would u think the lightened flywheel would have anything to do with it ??? as it was in reverse, it wouldnt GRAB for ****... anyone have any helpful tips as to what it would be ??
i dont know if this would do any help... but i have a 92 civic hatch... d15b motor... greddy turbo set up...
oh, i also forgot to mention... i CAN go backwards (reversE) but it has to be on a flat surface of no type of hill road... so pretty much, going up a hill or reversing up a SLIGHT hill, my car wont even make it up...
Old Sep 10, 2005 | 07:40 PM
kingSfit's Avatar
looks like ur slipping , did you have the clutch profess. installed?
Old Sep 10, 2005 | 07:48 PM
boosted civic 2k6's Avatar
Default Re: HELP ! CANT EVEN REVERSE or GO UP HILLS !!! (NeWnMpR0VeD)
haha very interesting problem. my thoughts are your flywheel is too light? lol. actually with a super light flywheel you lose momentum with the engine. lets use a random example. 20lb wheel spinnin then u apply the clutch vs 10 lb wheel wen u apply the clutch. the laws of physics dictates u have less power "SAVED UP" with a light flywheel. therefore u must slip ur clutch more or else face a stall when going from a stop.
i would think that even though its a lightweight flywheel..wouldn't the motor make enough power to still go up a hill? very weird. i'm not too familiar with lightweight flywheels. i know you must rev faster but HMM. maybe it makes you lose torque? lol.
or wait. MAYBE UR MOTOR DOESNT EVEN MAKE THAT MUCH POWER? it should? lol. maybe u got a fked up motor. but i would go with the theory that ur clutch is slipping if you can smell it that bad. probably installed improperly or you forgot something. i think that makes the most sense. good luck man.
Old Sep 11, 2005 | 09:12 AM
^^ thanks for the replies... it wasnt professionally installed... but its not like he was a newb... i'll have it checked out again
Old Sep 11, 2005 | 09:22 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: (NeWnMpR0VeD)
might be your cat, pull out your o2 and unplug it, drive again and see if you have more power
Old Sep 11, 2005 | 09:26 AM
G2 Speed's Avatar
Default Re: (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">might be your cat, pull out your o2 and unplug it, drive again and see if you have more power</TD></TR></TABLE>
no
Old Sep 11, 2005 | 09:39 AM
Luserkid's Avatar
Default Re: (G2 Speed)
Sounds like somethings wrong with the motor. If the clutch was slipping the RPMs wouldnt stay at one place. Could also be that you have a DX tranny, those suck *** and you would need to down shift on every little change in the road to keep your momentum.
Do you know what mph your redline shift is?
Old Sep 11, 2005 | 12:33 PM
95DxSi-R2
Guest
Posts: n/a
why
Old Sep 11, 2005 | 07:55 PM
i believe the redlines at 6800.. if its my motor, then why's the clutch smellin so bad... i dont think its the motor, its very strong for what it is... i do have power on flat surfaces but when its going up hills its a different story
Old Sep 11, 2005 | 07:57 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">why</TD></TR></TABLE>
he's saying reverse or go up hills, if his cat was clogged or his o2 sensor was messed... it would cause his driving everywere to be messed not just up hill
Old Sep 11, 2005 | 08:16 PM
EG6 SiRII's Avatar
New User
did you use brake cleaner to clean the surface of the clutch and flywheel before installation?
Old Sep 12, 2005 | 10:39 AM
my friend who put it in for me is saying "its just the break in period ".. i'm thinking that it absolutley has nothing to do with the breaking period... hmm, what to do...
and i'm not too sure if he used brake cleaner to clean the surfaces of the clutch and flywheel... all i saw was him bolting it on and thats it... and no its not my cat, cuz i dont have one
Old Sep 12, 2005 | 11:00 AM
sockvtec's Avatar
definatly get that clutch checked out, make sure it was installed properly....
Old Sep 12, 2005 | 11:19 AM
gftgrill's Avatar
even when I was breaking in the new clutch in my car, it would go up hills.
are you using the right ecu? I would think it had something to do with the clutch, flywheel or transmission.
for some reason it sounds like you're not getting power to the ground
Old Sep 12, 2005 | 11:55 AM
yeah i'll have it checked out.... and another thing, if i dont release the clutch fast when i'm engaging in 1st gear, it vibrates hard as hell... and i know the clutch isnt that strong/stiff... it has something to do with the flywheel... if i release the clutch very slowly, u can see/feel the passenger side axle vibrating so hard that it makes a loud *** noise.... not a high pitch noise, as noise as if u were shaking a metal in a plastic cup very hard...
Old Sep 12, 2005 | 07:29 PM
man, i just pulled up my driveway and fried the clutch bad... i revved it to 2 and released the clutch not too fast and it made that spinny noise again... and all this smoke came out
Old Sep 13, 2005 | 07:28 AM
gftgrill's Avatar
it definately sounds like something is wrong with the clutch. I can drop my clutch from 6k and it will spin the **** out of the wheels.
Old Sep 13, 2005 | 09:11 AM
crashN2u's Avatar
Default Re: (gftgrill)
same thing happened to my mom. if she wasn't on flat ground, she wasn't movin. even if she was on flat ground, she was barely movin. clutch was toast.
Old Sep 13, 2005 | 09:52 AM
Kouki-EK9's Avatar
Just sounds like a bad or poorly installed clutch.
lolv8s
Honda Civic (2006 - 2015)
30
Mar 23, 2017 03:36 AM
itslogz
Mar 19, 2008 02:24 PM
spoonlongblock
10
Nov 9, 2006 08:03 PM
phoenixR
Dec 26, 2002 06:02 AM
MrSmith
Feb 23, 2002 02:49 AM
