Dizzy rotor button
Old Sep 10, 2005 | 05:58 PM
C2daIzZle's Avatar
Default Dizzy rotor button
I was going to replace my ignition coil today with a high output io, however, when i removed the distributors cap.. i couldnt figure out how to remove the rotor that turns with the plugs.. i didnt want to mess with it much however i couldnt find anyway to remove it. Anybody have any insight?
Old Sep 10, 2005 | 08:12 PM
civic_driver's Avatar
there's a screw that holds the rotor to the distributor shaft... it's easiest to remove when the screw is on top... if you can't see it, you need to crank the motor so it moves into position
97SS
May 12, 2009 10:07 PM
lmike6453
Feb 22, 2008 07:34 PM
doggunracing
Nov 6, 2003 09:24 PM
93SSPHatch
May 30, 2002 02:55 PM
blackls
Jul 5, 2001 07:31 PM
