slamming into gear
Old Sep 10, 2005 | 03:00 PM
acuramike's Avatar
Default slamming into gear
i have 95 se teggy. in the morning when i put into drive it slams into gear. the only time it does not slam into gear is when i let the car warm up.and i flushed the tranny out like 6 months ago ,and the car slammed into gear ever since i got .
Old Sep 10, 2005 | 03:22 PM
Cliffjumper2's Avatar
Default Re: slamming into gear (acuramike)
if there are no other symptoms, check your motor mounts...specifically your rear mount or front torque mounts.
Old Sep 11, 2005 | 06:01 AM
Sam92Teg's Avatar
Default Re: slamming into gear (Cliffjumper2)
If you are describing an auto tranny, it might just be because your high idle at warmup is causing it to hammer into gear. If your car is sitting at a higher idle, it stands to reason it will hit into gear harder when you switch to reverse or drive.
Does it do it when you are at a 750 rpm idle?
Old Sep 11, 2005 | 06:32 AM
Backk InTheDA's Avatar
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuramike &raquo;</TD></TR><TR><TD CLASS="quote">i have 95 se teggy. in the morning when i put into drive it slams into gear. the only time it does not slam into gear is when i let the car warm up.and i flushed the tranny out like 6 months ago ,and the car slammed into gear ever since i got .</TD></TR></TABLE>
My car does this, but i need new tranny mounts, im associating the problem w/ this.
NA JDM GSR
Nov 1, 2006 07:45 PM
L8ApexH22
Oct 29, 2004 08:35 PM
Jake
13
Mar 11, 2004 11:33 AM
el arbi
Apr 21, 2003 09:31 PM
Nvious R
Apr 12, 2002 06:56 AM
