can someone help? wheel leaning
Not knowing the year / model of your Honda, I can only speculate.
I would suspect lower or upper inner control arm bushings (most likely)
worn lower ball joint (less probable)
Check these first.
If this is a third (3d) generation Accord or earlier, this isn't an uncommon failure (it seems to be a constant battle of ball joint and bushing failures).
If it is fourth (4th) generation or later, this is not as common
In both cases it stands having it looked at
P
Check these first.
P
also chk the upper shock (strut ) mount. , upper ball joint ,i have seen a few of those break
As a suggestion,,,, i would not drive the car if i were you ,there definatelly is a broken suspension part ..
gnx547
Jan 7, 2009 02:18 PM
stillrockin18s
Sep 27, 2005 11:57 AM
