what compression do i need to moifiy with head?
Old Sep 10, 2005 | 12:21 PM
careawholelot's Avatar
Default what compression do i need to moifiy with head?
hey im under mw friends name but i was building my b20 vtec and was trying to figure out what compression you need to start modifying head and what the highest is without modifiying it. let me know thanks. Hella 3rd
Old Sep 10, 2005 | 04:25 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: what compression do i need to moifiy with head? (careawholelot)
one more time in engrish please
Old Sep 11, 2005 | 10:27 AM
Default Re: what compression do i need to moifiy with head? (PURPLETERROR)
whats the highest compression i can go without modifying head valves whatever
Old Sep 11, 2005 | 10:45 AM
k24a4kid's Avatar
I'm a Jackass
you dont have to modify anything.. i run 13.2:1 and heave a stock head and valve train
Old Sep 11, 2005 | 11:40 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: what compression do i need to moifiy with head? (turbofienD 04)
You usually only modify things in the head to get to the comp ratio you want. Compression ratio doesn't require you to beef the head or really anything up for that matter. It just requires very accurate tuning and good gas.
Old Sep 11, 2005 | 12:06 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: what compression do i need to moifiy with head? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">You usually only modify things in the head to get to the comp ratio you want. Compression ratio doesn't require you to beef the head or really anything up for that matter. It just requires very accurate tuning and good gas.</TD></TR></TABLE>
than better than i ever could of put it
Techna600f4i
Jun 19, 2006 11:49 PM
Y2A
Mar 4, 2005 09:03 AM
digital sol
Feb 1, 2005 07:58 AM
gavhowe
Aug 2, 2002 07:03 AM
