HAsport B series mount kit info needed
Old Feb 27, 2002 | 07:46 AM
dumbchild's Avatar
Default HAsport B series mount kit info needed
putting a B18 into my 88 crx si - if I use the HASport mount kit - does the engine bay still require clearancing in the form of grinding away at crossmembers etc? or is it just a straight bolt in?
Old Feb 27, 2002 | 07:53 AM
EP3_05's Avatar
Default Re: HAsport B series mount kit info needed (dumbchild)
If you run a 4-1 header you will need to notch the cross member. You will also need to bang in the framerail to clear the alternator pulley and bend down the rear crossmember so the rear motor mount bracket does not rest on it. It is very simple and everything else just bolts right in.
Old Feb 27, 2002 | 02:41 PM
dumbchild's Avatar
Default Re: HAsport B series mount kit info needed (91civic)
thanks!!
deemy72
Aug 30, 2009 01:49 PM
birdricer
May 7, 2007 05:43 PM
w-fuck-ay
11
Aug 3, 2003 09:15 PM
lowboost civ
Mar 9, 2003 07:23 PM
