will this manifold fit in a 90civic si?
Old Sep 10, 2005 | 09:45 AM
B18 CYA's Avatar
Default will this manifold fit in a 90civic si?
any info on what would need to be done to make it fit?
Old Sep 10, 2005 | 10:01 AM
2kTeg's Avatar
Default Re: will this manifold fit in a 90civic si? (B18 CYA)
its a b series ram horn on a bseries motor so if you have a bseries then yes it will go on
Old Sep 10, 2005 | 10:23 AM
B18 CYA's Avatar
i know it will go on a b-series but what will be need to done in an ef to make it fit? cut out the hood latch support thing?
Old Sep 10, 2005 | 10:28 AM
90civichbsi's Avatar
Default Re: (B18 CYA)
those manifolds need about 7.5" of clearance in front of the runners. about the only way to make it fit is run a full-race modified pwr radiator. and you should be able to keep your stock crossmember http://www.full-race.com/catal...d=481
eviltwin66six
Nov 17, 2006 06:34 PM
redracer1024
Honda Fit
May 3, 2006 10:04 AM
torqueless
Dec 31, 2004 08:33 PM
hatch808
Sep 8, 2003 04:37 PM
xci_ed6
Jan 12, 2003 02:52 PM
