n/a header noise?
Old Sep 10, 2005 | 08:05 AM
5thGenFanatic's Avatar
Default n/a header noise?
im using a jdm b swap in a 92 4 door... i never used a n/a header before on a b-series .. i put an obx stainless one on last night and is it normal to hear a ticking sound coming from the header area of the head and a tapping drumroll sound when hitting the gas while driving?
Old Sep 10, 2005 | 08:10 AM
BlackLudeSi's Avatar
Default Re: n/a header noise? (5thGenFanatic)
Sounds like you have an exhaust leak somewhere, pretty common on tubular steel headers. Did any manifold bolts break? Are all the gaskets in correctly and tightened? Thats what I'd check first
Old Sep 10, 2005 | 08:16 AM
Default Re: n/a header noise? (BlackLudeSi)
thanks..i was thinking so also...i had to reuse the stock manifold gasket because the one they sent ..the ports were too small for the head...the header was right but the gasket doesnt fit...i think i might try dremeling it out and see if that works
Old Sep 10, 2005 | 08:24 AM
Or just got pick up a copper one! They are pretty cheap and will last for ever compared to a fiber one
Old Sep 10, 2005 | 08:28 AM
badass thanks?...does the thickness make a diff? the stock is thin and the new one is thick with it help with airflow to get a thicker one?
Old Sep 10, 2005 | 08:31 AM
Eh not really gonna matter enough to make a difference. Just get a copper one, mine has 13,000 miles and still looks brand new, no leaks either
Old Sep 10, 2005 | 08:36 AM
ok i found one im gonna order it..but i have 1 more Q...i have a jdm motor and my intake manifold and ports are bigger ... do u think the reason i had a prob with the gasket is the ports?...are the exaust ports diff too or just the intake?
kellogg97rs
Sep 27, 2007 12:15 PM
5thGenFanatic
Sep 26, 2005 02:19 PM
5thGenFanatic
Sep 10, 2005 04:36 PM
5thGenFanatic
Sep 10, 2005 10:42 AM
Broken Gearbox
Feb 27, 2004 03:47 AM
