diff. Vtec sound when switching to aggressiver cams?
Old Feb 27, 2002 | 07:04 AM
austrian type-R's Avatar
Default diff. Vtec sound when switching to aggressiver cams?
Has the sound of the Vtec changed when you are using Juns/Todas/Skunk................camshafts?
Is it now louder than with stock cams?
Old Feb 27, 2002 | 07:11 AM
DutchITR1689's Avatar
Default Re: diff. Vtec sound when switching to aggressiver cams? (austrian type-R)
I think the bigger and/or the faster the lift the louder the intake noise......
Like a Type R compared to a normal B16A.
Old Feb 27, 2002 | 07:12 AM
Mike K's Avatar
Default Re: diff. Vtec sound when switching to aggressiver cams? (EuroITR1689)
Hell yes it's louder.
JUN3's going into VTEC is sick.
Old Feb 27, 2002 | 07:13 AM
GarageQueen213's Avatar
New User
I think the noise would be slightly louder.
However I've never used the "aggressiver" cams before.. Whats the lift on those puppies??
Sorry, had to do it.
[Modified by GarageQueen213, 11:14 AM 2/27/2002]
Old Feb 27, 2002 | 07:19 AM
B18CXr's Avatar
B xover is very quite compared to stock cams.
Old Feb 27, 2002 | 07:24 AM
TypeR0149's Avatar
yes VTEC is hella loud with JUN cams
Old Feb 27, 2002 | 07:26 AM
SpecR_EK's Avatar
New User
Default Re: diff. Vtec sound when switching to aggressiver cams? (Vegeta)
Anyone have any soundclips?
Old Feb 27, 2002 | 07:41 AM
NAB20C5's Avatar
Default Re: diff. Vtec sound when switching to aggressiver cams? (SpecR_EK)
I believe Tony the Tiger on the board has an actual vid w/ sound clip, IM him
BTW he has Toda B's
[Modified by NAB20C5, 4:41 PM 2/27/2002]
Old Feb 27, 2002 | 07:42 AM
nerdish's Avatar
Default Re: diff. Vtec sound when switching to aggressiver cams? (NAB20C5)
I used to have that video but now I can't find it... I like his car.
Old Feb 27, 2002 | 07:48 AM
Default Re: diff. Vtec sound when switching to aggressiver cams? (B18CXr)
That's because the non-vtec cams are already agressive....
Old Feb 27, 2002 | 08:03 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: diff. Vtec sound when switching to aggressiver cams? (Mike K)
with the toda b's, i have no vtec sound..... i kinda miss it though.
Old Feb 27, 2002 | 08:04 AM
NAB20C5's Avatar
Default Re: diff. Vtec sound when switching to aggressiver cams? (rodney)
Still havn't Figured out why Vtec isn't working Rod-knee?
Old Feb 27, 2002 | 08:25 AM
Liquidx02's Avatar
Yes, VTEC crossover on JUN IIIs is sick. Your whole county will hear u hit VTEC. JUN III with high compression sounds even meaner.
Old Feb 27, 2002 | 08:30 AM
Default Re: diff. Vtec sound when switching to aggressiver cams? (Rattlesn8ke)
DAMN! I need a 2nd ITR with Jun 3
Old Feb 27, 2002 | 10:15 AM
azn98R's Avatar
yeah, it gets louder... all you hear is a click and then BAAAAAAAAAAAA!!!!! Music to my ears, by the way I also have Jun3's
Old Feb 27, 2002 | 11:27 AM
Mike K's Avatar
thanks for informing us, Mr.Wizard.
see you at the meet.
Old Feb 27, 2002 | 11:40 AM
Rodney's Avatar
actually, i did figure it out...it was a torn intake orifice seal. oops...i can't hear the switchover unless i'm in a tunnel or next to a long wall, and even then it's faint. but, it's still fast. i dynoed 194/132. i even impressed myself.
Old Feb 27, 2002 | 01:06 PM
E46M3CB's Avatar
just for clarifications...
Toda - you lose the vtec sound?
ONLY Jun 3's - Enhances Vtec sound?
what bout skunk cams?
Thanks.
I'm looking into buying new cams pretty soon... so I need some help deciding.. Thanks...
Old Feb 27, 2002 | 01:48 PM
alexboy's Avatar
I wish i could here mine
Currently going through engine brake in with about 950 miles to go
Old Feb 27, 2002 | 01:54 PM
SpecR_EK's Avatar
New User
Default Re: diff. Vtec sound when switching to aggressiver cams? (alexboy)
I've heard Tony's car before
I wonder if anyone's got clips of their car with JUNs
Old Feb 27, 2002 | 02:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: diff. Vtec sound when switching to aggressiver cams? (serenity)
Thanks.
I definately wouldn't base my choice of cams on the VTEC sound they produce. That being said, a rough indication of how the VTEC transition will be with a particular cam can be determined by comparing the respective sizes of the primary/secondary and VTEC lobes. JUN's primary/secondary lobes on their Type III's are not as agressive as say, those on Toda's Spec B's. This is why the VTEC transition is more pronounced, since there is more of a size difference between the lobes. This is also the reason why it takes far less tuning to achieve a "near-stock" idle on Type III's than with Spec B's. The Todas are idling on lobes that are roughly the size of stock ITR VTEC lobes, and this obviously takes some tuning to smooth out the roughness (unless of course you don't mind that sort of thing ).
[Modified by SpecR0123, 6:19 PM 2/27/2002]
S2kgotswag
43
May 14, 2013 11:35 AM
92B18Bvx
12
Aug 21, 2004 06:53 PM
tecnic1
Mar 5, 2002 09:07 PM
905_S2K
Feb 15, 2002 11:54 PM
duduvr6
Oct 9, 2001 01:30 PM
