Dammit, whats wrong with my car?
Old Feb 27, 2002 | 07:02 AM
R59's Avatar
R59
Default Dammit, whats wrong with my car?
I've got stuck a couple times...It cranks but just won't turn over..I thought the battery was going, but even with a jump it won't start..After an hour or so, it usually starts again, then it'll go a week without a problem..Last night though, it got stuck while i was visiting my parents, and this morning it still won't start..Same thing, the crank sounds healthy but it just won't ignite..The other strange thing is, when this happens, i still have all my power; radio, antenna, heat, everything except the windows..Power windows won't work at all..Luckily we were able to push my car into their garage because my window was stuck down and it was starting to rain...
It's going to Acura tomorrow..Unfortunately it will probably have to be towed there..Any ideas?? I really don't have time to figure it out but would love to get an idea before i bring it in....I still think its the battery..thanx
[Modified by spoooky, 11:03 AM 2/27/2002]
Old Feb 27, 2002 | 08:32 AM
slash00R's Avatar
New User
Default Re: Dammit, whats wrong with my car? (spoooky)
Same thing happened with an old Celica gt-s I used to have. I thought it was the computer or alternator, but it turned out to be the battery as well .. engine conked out when I operated the windows. Seems the alternator had to diverte too much juice to the battery to try to recharge it, which stalled the engine
Good luck
Old Feb 27, 2002 | 10:04 AM
R59's Avatar
R59
Default Re: Dammit, whats wrong with my car? (slash00R)
If it is the battery, shouldn't i be able to jump it??
Old Feb 27, 2002 | 10:09 AM
Xian's Avatar
I'm guessing that it is the ignitor that has gone out. If you aren't getting spark then the car isn't going to start
Old Feb 27, 2002 | 10:11 AM
AssPenny's Avatar
Default Re: Dammit, whats wrong with my car? (Xian)
Pull the plugs out and put them in the plug wires and set the plug body on some bear metal so it is grounded out. Have some one turn the car over and see if there is any spark. If not, then try replacing your cap and rotor (cheap) and its still not working pull out the helms and look at the trouble shooting for the distributer.
Old Feb 27, 2002 | 10:16 AM
Xian's Avatar
Default Re: Dammit, whats wrong with my car? (AssPenny)
you can also pull the plug wire and stick a screw driver in the end... have someone crank the engine and see if there is spark from the screw driver to ground. Same thing as the sparkpulg trick but requires less tools Good idea about checking the cap and rotor but I'm sticking with it being the igniter.
Old Feb 27, 2002 | 10:17 AM
houston's Avatar
do you run a rich fuel mixture? could be hard to ignite.. or might have completely clogged the damn cat.. ever smell rotten egs when you driving?
Im guessing its the ignitor though... all hondas seem to eat ignitors..
and the autozone ignitors last about a week.. though they have a lifetime guaruntee.
KILLAB17VTEC
Oct 8, 2009 08:02 PM
nighttrain33
13
Jun 16, 2007 10:32 PM
coronadrinker
May 28, 2007 02:47 PM
sinfulj32
Sep 25, 2006 12:08 PM
MikeTV
Nov 9, 2004 01:56 PM
