Suspension & Brakes Theory, alignment, spring rates....
FWD Tuning
Old Sep 9, 2005 | 11:13 PM
CTR-GSR's Avatar
Default FWD Tuning
Can a suspension pro please tell me the best set ups for a track Front wheel drive. I want information regarding toe angle, ride heights, and cambers for both front and rears. TY TY
Old Sep 10, 2005 | 06:40 AM
Solracer's Avatar
Default Re: FWD Tuning (CTR-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR-GSR &raquo;</TD></TR><TR><TD CLASS="quote">Can a suspension pro please tell me the best set ups for a track Front wheel drive. I want information regarding toe angle, ride heights, and cambers for both front and rears. TY TY</TD></TR></TABLE>
It all depends on what you are going to be doing with the car, thiere is ni :best: set up, it all depends on driving style, track conditiosn and such.
Old Sep 10, 2005 | 08:17 AM
CTR-GSR's Avatar
Default Re: FWD Tuning (Solracer)
I see, so there is no general trend on good FWD suspension like camber or toe angles?
Old Sep 10, 2005 | 09:07 AM
L33t A2's Avatar
Is this car gonna be daily driver and also a weekend track car or what.
If its a mostly street car, then I wouldnt go for more than 2 degrees negative camber in the front, and keep that toe zeroed. Otherwise youll get some really bad tire wear.
Old Sep 10, 2005 | 09:34 AM
CTR-GSR's Avatar
Default Re: FWD Tuning (L33t A2)
Yea i was thinking if I wanted to do track only, without tire wear as a concern. What would be the best setting without any concerns for durability of tires.
Old Sep 10, 2005 | 10:50 AM
ohjolt2's Avatar
Your in the wrong forum, all suspen sion questions of a technical nature concerning actual performance beling is AX/RR, this is just the blinging wheels and how low can i go with stock shocks forum.
Old Sep 10, 2005 | 11:38 AM
Solracer's Avatar
Default Re: (ohjolt2)
The most common track setup in the us is a larger rear sway bar, high rate rear springs (any where from 500-1500). Sometimes a stock front bar or no bar, and springs rates in the 350-700 range.
soclean1k_JDM
Suspension & Brakes
Jun 30, 2009 05:26 AM
Jdmls
Jul 19, 2007 06:28 AM
MtnCRX
Suspension & Brakes
Mar 26, 2005 03:30 AM
Greyout
Oct 3, 2003 02:53 AM
1GreyTeg
Aug 18, 2003 12:34 PM
