Japanese K series Type R cams
Old Sep 9, 2005 | 10:55 PM
sinisterSi04's Avatar
Default Japanese K series Type R cams
can anyone help me out with the engine number and type of cams on a Japanese K series SiR? ... lookin' to switch the ones out of my K20A (2004 civic si)
Old Sep 9, 2005 | 11:25 PM
DC5ITR329's Avatar
Default Re: Japanese K series Type R cams (sinisterSi04)
if you have a stock 04 Si and you have a K20a3 motor you can't swap the cams.
Old Sep 10, 2005 | 05:08 AM
Default Re: Japanese K series Type R cams (aznbo1626)
****, you're right ... it's cause of the two lobe versus the three lobe right? ... wat can i swap in there? wat parts are interchangeable between the a2 and a3?
Old Sep 10, 2005 | 06:05 AM
ekek888's Avatar
the heads are diff. but the block is basically the same.
Old Sep 10, 2005 | 09:17 AM
DC5ITR329's Avatar
Default Re: Japanese K series Type R cams (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 &raquo;</TD></TR><TR><TD CLASS="quote">the heads are diff. but the block is basically the same. </TD></TR></TABLE>
actually blocks are different. the A2 has extra oil squitors for higher RPMs.
Old Sep 10, 2005 | 09:18 AM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinisterSi04 &raquo;</TD></TR><TR><TD CLASS="quote">****, you're right ... it's cause of the two lobe versus the three lobe right? ... wat can i swap in there? wat parts are interchangeable between the a2 and a3?</TD></TR></TABLE>
you can do a head swap but I think frankenstein engines are not so reliable. If I were you I would save up for a Type S motor and swap. you get a better platform to start modding. or if you don't want to do that you can just do the regular IHE and hondata. that should still give you some power.
Old Sep 10, 2005 | 04:29 PM
Vaztec's Avatar
You can't install k20R cams into your EP3. THe heads are different and plus the K20R has three roller rockers instead of two from the EP3. To do that swap properly you would need to swap the whole valvetrain from the DC5-R onto your EP3 head except the valves. I dont know if it will fit. It is not like a interchangeble b series. good luck.
98EK20
Jan 3, 2008 04:20 PM
bomber19
Aug 15, 2007 12:32 AM
949legalEG
May 16, 2005 11:00 AM
acuraqc
Jun 14, 2004 08:48 PM
HapaHaole
Acura TSX
May 10, 2004 10:33 AM
