Disconnect an Intenna ?
Does anyone kno how to disconnect an Intenna ( Power ) on a 91 Teg LS ??? im not sure how to do it..and when i turn the car off...it makes a weird noise when it goes down...
Thanks guys
Thanks guys
the power motor is most likely going on it. look in your trunk and pull some panels back and look behind them (left side of trunk) should be able to unplug it from the motor, or possibly a fuse you can pull.
bump for someone elses opinion
"i shaved mine off along with the motor, drivers side trunk, behind the plastic trim its right there and its on the side of the motor."
-How do u shave it off.. ?? and / or... DO i need to take the Whole left back panel off to get to it...or can i get to it by the tail light panels ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk »</TD></TR><TR><TD CLASS="quote">Does anyone kno how to disconnect an Intenna ( Power ) on a 91 Teg LS ??? im not sure how to do it..and when i turn the car off...it makes a weird noise when it goes down...
Thanks guys </TD></TR></TABLE>
You can pull the radio out, and clip the solid blue (usually dark blue) wire on the harness which gives power to your power antenna, that will stop it from going up and down.
as to why it makes that noise, it's not the motor. It's the antenna mast or more accurately, the little teeth along the white plastic cord has probably been stripped of a few, and now it slips when trying to retract thereby making those weird sounds.
You can find used antenna units for the 2nd gen and third gen tegs fairly cheap in the classifieds ($25 or less), or you can go with an s2k conversion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk »</TD></TR><TR><TD CLASS="quote">-DO i need to take the Whole left back panel off to get to it...or can i get to it by the tail light panels ??</TD></TR></TABLE>
With the DA's, the panels are fairly flexible, you won't have to remove the entire panel, just remove the cover panel by the tail lights,a nd unclip a couple clips from the rear of the side panel, it should bend enough to let you get at the antenna unit.
and either a used da or dc antenna unit will work for your teg, you would just have to reuse your antenna unit mounts if you get one from a dc (94-01_ integra).
camera obscura
May 15, 2003 06:50 AM
