Help with wiring a 4 channel amp in 2000 Honda Accord ex with stock double din cd player
Old Sep 9, 2005 | 11:38 AM
humble007's Avatar
Default Help with wiring in 2000 Honda Accord ex with stock head unit like which is remote turn on wire
I am installing a 4 channel amplifier a single 10 inch sub to my stock head unit.
I have removed the radio and have isolated which wires are going to which speaker, but i have 2 questions:
which wire is the remote turn on wire? and
does the front tweeters come off the front wiring or are they seperately wired straight to the head unit?
I don't want to amplify the tweeters as well, so should i just disconnect them? I have 3-way speakers or should i get some pyramid tweeters and hook them up in their place?
I am running an Infinity amplifier rated at 111 watts RMS.
Your help is greatly appreciated!!!
Thanks
Paul Dallas
Modified by humble007 at 1:42 PM 9/9/2005
Old Sep 9, 2005 | 02:45 PM
humble007's Avatar
Default Re: Help with wiring in 2000 Honda Accord ex with stock head unit like which is remote turn on wire
okay i figured out the remote turn on wire i think:
i am using the ignition accesory wire
but i still need help figuring out whether the tweeters are hooked at the head unit or after the head unit just splitting off the front speaker wires
Old Sep 11, 2005 | 09:52 PM
91teggyman's Avatar
ignition wire is right .......now the tweeters are connected to the radio and speakers DONT touch them..wat u do is get this little box called a high to low it has wires on one end and rca's inputs on the other...radio shack is ur freind ......on the box is 4 wires colored like two grey and two white each pair is for 1 speaker use ur rear speakers tap into those wires cause all ur amp needs is a sound signal from ur rear speakers two wht to 1 speaker and two grey to the other ..now since the box only have two rca's and ur amp is 4 channel u need to buy y jacks..radio shack one end female and other end two males you need two of those and a 3to6 feet rca wire....so high to low box to long rca to y jacks to amp ur done then wire up ur sub to two channels briged and ur new tweeters to the other two----1 tweeter a channel and if the amp has built in crossover which is a button that says high/mid/low (tweeters on high and sub on low) ..............THATS IT hope that helps man
Old Sep 12, 2005 | 12:00 PM
humble007's Avatar
Yeah i was thinking i could do that, but then i would lose my stock fade and balance controls on my radio, and on top of that my amplifier has speaker level inputs, thanks though.
Old Sep 12, 2005 | 03:43 PM
91teggyman's Avatar
no u won't lose ur fade out ...just when u fade ur rear speakers in and out ur sub and tweeters will do the same
TimS
Nov 24, 2007 12:54 AM
sweetdang
Audio / Security / Video
Jul 20, 2007 07:28 AM
projectcivicsl
11
Mar 25, 2005 08:29 PM
lDanny
Jul 10, 2004 03:02 PM
zcivicz
Mar 24, 2003 05:04 PM
