Removing the wiring harness to the Fuel Injectors
Old Sep 9, 2005 | 07:11 AM
MyRex's Avatar
Default Removing the wiring harness to the Fuel Injectors
I'm trying to remove the wiring harness to the fuel injectors on my D series engine as well as my ZC engine and cannot figure out how to unplug the harness plugs from the injectors??? Not sure if a special tool is needed? I wouldn't think so...?
Any suggestions on technique?
Thanks!
Old Sep 9, 2005 | 11:19 AM
steveobb4's Avatar
Default Re: Removing the wiring harness to the Fuel Injectors (MyRex)
Do you have a pic set, there are little metal clips holding the connectors on, pry them off carfefully or they will go flying.
Old Sep 10, 2005 | 08:24 PM
IGotNoSwap's Avatar
Default Re: Removing the wiring harness to the Fuel Injectors (steveobb4)
i just removed my wire harness of my 91 crx. (swapping to b18c).
there is a small metal pice as a clip on the injectors. take a flathead screwdriver and pry SLOWLY between the plastic and the metal piece.
tailoredtune
20
Nov 1, 2011 08:15 PM
gnd101
Jan 15, 2009 01:40 PM
DFW
12
Jun 8, 2006 10:20 PM
sleepyhamsterlx
Nov 28, 2003 02:01 PM
